Headlight dilemma. Need adivce.
Not sure if this issue is common. On my front passenger headlight, sometimes it works but most often it doesn't. I changed the bulb and the problem persists. I noticed if I tap the headlight with my fist it'll go on but then it might turn off again. I've even cleaned the contact points between the bulb and the light assembly. It's driving me nuts looking at the change bulb sign on my dash. Now the left turn signal is doing the same. Is it a wiring problem? Can't be the fuse. Help. My headlight assembly is factory.
Danke.
Danke.
audiandrew1
05-29-2008 05:40 AM
mmart6545
07-23-2005 07:39 PM
petercyeh
03-28-2005 02:52 PM
eroc
12-24-2002 01:47 PM
