Headlight help,,,,,,,,HELP before i spend another $500
Old 05-16-2005, 07:53 PM
Silver_Patrone's Avatar
Default Headlight help,,,,,,,,HELP before i spend another $500
I bought US spec Bi Xenons, now when the shop was installing they called and said the ballasts did not work as the connectors did not work...
Now i was told that some 02s have D2S Bulbs and ballasts, so i assumed that i too had the D2S and that was the problem
Well. I took mine old lights out today and found that the i do have the D1S Bulb and ballast. the only connector that is differnt is the one from the main plug in to the ballast... its a red and brown wire...
Can i cut and resplice the connector from my stock to the new housing?
ANY one do this ? is this an issue. now the bulb fits the houseing and locks in we are talking about 2 wires?
please help
thanks.
Old 05-16-2005, 07:58 PM
AudiWorld Uber User
MB The Body's Avatar
Default i was unable to get ecodes... because i have an early 02...
and my hid ignitor had a round (pear shaped) based while the ecodes all had a square base...
as for the connector yes you can modify the connector to work if thats your only problem...
just make sure you dont have the bulb situation i had
Old 05-16-2005, 08:04 PM
Mine is square......Just the 2 wire power to the lead to the ballast is differant.
Old 05-16-2005, 08:05 PM
Re: Mine is square......Just the 2 wire power lead to the ballast is differant.
Old 05-16-2005, 08:09 PM
AudiWorld Uber User
Default im pretty sure you can take the connector from the old headlight and solder in to the new one ....
but don't quote me on that until someone seconds that... i know you could do that for the standard xenons i just dont wanna say for sure on the bi-xenons....
i wish i had the square base i got totally screwed
Old 05-16-2005, 08:33 PM
Default pictures/
<img src="http://pictureposter.audiworld.com/6174/headlight_old.jpg">
Old connector
<img src="http://pictureposter.audiworld.com/6174/headlight1.jpg">
New Connector on the Bi Xenons
Old 05-16-2005, 08:41 PM
Super Gohan II's Avatar
Default i just installed my S4 Ecode Bi-Xenons,
and yes you have to splice the wires, its not too hard. if i can do it, u can do it.
Old 05-16-2005, 08:48 PM
Re: AWESOME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Old 05-16-2005, 09:21 PM
SilverTQ's Avatar
Default heres a write-up on how to fix that
<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/598802.phtml">clicky</a></li></ul>
Old 05-17-2005, 05:47 AM
LOL those are my wires too
fmladineo
Q7 MK 1 Discussion
9
05-03-2022 10:55 PM
bballfreak
9
04-14-2019 06:59 PM
Kerry G
05-18-2018 06:12 AM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
mxp
09-26-2015 10:15 AM
Quick Reply: Headlight help,,,,,,,,HELP before i spend another $500
