Headlight Range Control Defective
I keep getting the symbol indicating that my dynamic range control is no longer working properly. I have a 2004 A4. Is this something I could possibly fix without the hassle of the dealer or do I need to take it in? Its annoying because the symbol will come on and beep every few minutes without me having the lights on.
then fix any problem/s revealed by the fault code/s that may exist in the module fault memory, after the repairs, clear the memory.
A VAG-COM tool is required to scan the auto-leveling control module for fault codes, and to clear the fault memory after repairs.
Thanks, that will work too. I noticed that the left and right light range adjustment fuse locations were empty. Fuse #20 & 21 with 15amps each. Fuse #10 looked fine. Could this be why the defective light keeps coming on?
same light came on for too along with oil sensor notification and oil pressure notification . Read this and went to the fuses. So I can atleast get rid of one annoying problem. Removed it and all notifications are gone.
RLee556 (06-15-2022)
LuxuryAutoKSA
RS 7
09-14-2015 04:30 PM
LuxuryAutoKSA
09-14-2015 04:30 PM
LuxuryAutoKSA
Q7 MKII Discussion
09-14-2015 04:30 PM
LuxuryAutoKSA
Q5/SQ5 MKI (8R) Discussion
09-14-2015 04:29 PM
LuxuryAutoKSA
Audi R8
09-14-2015 04:26 PM
