Help 18047
Help 18047
Hello everyone,
I am hoping someone can help me, having trouble with A4 b6 02 1.9tdi.
Trouble is I am getting no response from the accelerator and I am getting code 18047 from my friends VCDS.(actual code below)
We tried testing measuring block 062 but keep getting the error message.
We are getting throttle reading at 5% when actually it is not been touched. And 100% when foot to floor.
We tried swapping with a different working Accelerator pedal but same thing, we also measured the current from the 6 pin connector block on the accelerator pedal: pin 1+earth = 4.5v, 1+5 = 0, 2+earth = 4.9v, and 2+3 = 4.9v
Can anyone please tell me or point me in the right direction as to what it is?
Bad wiring?
Bad ecu?(ecu is dry and no wet on floor)
CODE FROM VCDS
Address 01: Engine Labels: 038-906-019-AVF.lbl
Control Module Part Number: 038 906 019 JQ
Component and/or Version: 1,9l R4 EDC 0200SG 1570
Software Coding: 00002
Work Shop Code: WSC 00222
Additional Info: WAUZZZ8EX3A114620 AUZ6Z0B0145673
VCID: 6FE7A2182D86136
1 Faults Found:
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 35-10 - Implausible Signal - Intermittent
Readiness: 0 0 X X X
Bad wiring?
CODE FROM VCDS
1 Faults Found:
MCPaudiTT - DEFCON 1
08-08-2007 07:18 PM
