Help with 2003 A4 avant electrical problems
I've replaced the battery and even the ignition switch in hopes of solving these problems with no luck. The Wipers, Turn signal and Window switches don't work. The AC unit works intermittently.
Here is a VCDS scan.
Thursday,30,August,2012,18:01:00:26406
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUVT68EX3A147468 Mileage: 195400km/121415miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 E HW: 8E0 909 059
Component: 3.0L V6/5V G 0001
Coding: 0016751
Shop #: WSC 63351 000 00000
VCID: 37770E3E4556A51
4 Faults Found:
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics
18043 - Powertrain Data Bus
P1635 - 008 - Missing Message from A/C Controller - Intermittent
18036 - Powertrain Data Bus
P1628 - 008 - Missing Message from Steering Angle Sensor - Intermittent
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8E0 927 156 Q
Component: AG5 01V 3.0l5V USA 0912
Coding: 0001002
VCID: 3C7D11127C70869
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04497
Shop #: WSC 06435
VCID: 2D5B2C56E70A1F1
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
P1628 - 35-10 - Missing Message from Steering Angle Sensor - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
VCID: 2953D846D3E2031
9 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-10 - Blocked or No Voltage - Intermittent
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
01330 - Central Control Module for Central Convenience (J393)
00466 - Control Module for Steering Column Electronics (J527)
49-00 - No Communications
00457 - Control Module for Network (J519)
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
00474 - Control Module for Immobilizer
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
2 Faults Found:
002 - Lower Limit Exceeded - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
002 - Lower Limit Exceeded - MIL ON
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 03200
Shop #: WSC 22163
VCID: 32613F2AFE34409
WAUVT68EX3A147468 AUZ6Z0B0207154
12 Faults Found:
00668 - Supply Voltage Terminal 30
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01334 - Door Control Module; Rear Right (J389)
01333 - Door Control Module; Rear Left (J388)
01320 - Control Module for Climatronic (J255)
37-10 - Faulty - Intermittent
01304 - Radio
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: EBDF624E999E511
2 Faults Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
01462 - Anti-theft alarm ultra sonic Sensor (G209)
End ---------------------------------------------------------------------
69 75 76 77
Coding: 0016751
4 Faults Found:
Coding: 0001002
Coding: 04497
Shop #: WSC 06435
2 Faults Found:
35-00 - -
Coding: 00000
Shop #: WSC 63351
9 Faults Found:
Coding: 0010607
2 Faults Found:
Coding: 03200
Shop #: WSC 22163
12 Faults Found:
01304 - Radio
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
43-00 - Closed
Another Scan from a week earlier.
Thursday,23,August,2012,21:49:48:26406
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN: WAUVT68EX3A147468 Mileage: 195390km/121409miles
Coding: 0016751
2 Faults Found:
Coding: 0001002
Coding: 04497
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
8 Faults Found:
Coding: 0010607
Coding: 03200
Shop #: WSC 22163
3 Faults Found:
01304 - Radio
Coding: 00001
Shop #: WSC 00000
Coding: 0016751
2 Faults Found:
Coding: 0001002
Coding: 04497
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
8 Faults Found:
Coding: 0010607
Coding: 03200
Shop #: WSC 22163
3 Faults Found:
01304 - Radio
Coding: 00001
Shop #: WSC 00000
i too am having probs of a similar nature .about amonth after buying my 2003 19tdia4 avant i had too park the car on some long grass soon after i was driving on the motorway when a mouse appeared on the nearside wiper blade ,needless to say he was very soon blown onto the road and at and just before this happend my probs started to occour DRIVER SIDE HEATER FAN TO THE WINDSCREEN INOP,TIME AND DATE INOP,DRIVER SIDE HEATER ONLY BLOWS COLD. IS IT POSSIBLE YOU PARKED YOUR CAR SOMWHERE A MOUSE OR MICE COULD GET IN TO YOUR UNDERBONNET?
That or water intrusion into fuse boxes such that the car still downloads codes, but is not communcation with the rest of the car. Not terribly familiar with the electrics, but know the comfort module, the ECU, and fuse box underneath the ECU are good places to start. Unfortunately, you will just have to start tearing into the car and look for a short somewhere. Case in point, I spent the better part of an afternoon looking for the componenet on my 300ZX that was causing my brake lights not to illuminate. Finally found a bad component in the back near the taillight.
joe@devitto.com
05-24-2017 02:26 PM
joe@devitto.com
05-22-2017 02:09 PM
