HELP!!! Auto-leveling
So i had my bilstein/h&r setup put in last week and i had the auto-leveling sensor come on. I took it to the dealer and they fixed it for about a day and now it is on again. I had a VW mechanic put in my suspension so im pretty sure everything was installed correctly. What should i do?
Had the same thing happen when I made suspension changes on my 2002 A4. The tech who made the changes put the leveling sensor (left rear wheel) on backwards. I took it three times to the dealer to find the problem and it took less than thirty seconds to fix it once they found it!
If I am messing with my VAG for any reason and loose basic settings in the headlight control module I have to go back and relearn the postions for them. However, this can not be done with the car all the way on the ground. Usually I will jack up the left side if the car about an inch (I am assuming you don't have a lift at home and will be using a jack) and then go in and relearn the new postition. This works every time. I only have an issue if I am screwing around with my VAG.
TeddyBGame
16
09-19-2013 04:17 AM
Audi_in_Van
03-22-2007 07:47 AM
Cush
04-11-2006 12:59 AM
