Help! Checklight came on and pulled the fault codes
going up a slight incline and Check light came on. Drove to next exit and pulled over. Pulled up the hood and didn't see anything out of the ordinary. No leaks etc. Even checked the oil just to make sure. Oil was kool.
Drove the car home-about 10 miles. Engine sounds fine, still getting power and boost (i think), engine is not misfiring or doesn't sound weird. anyway, pulled the codes;
1 Fault Found:
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded - Intermittent
Sounds like I'm not boosting?? Any help would be greatly appreciated. I already cleared the code but have not taken my car out to see if it comes out again. Tx.
1 Fault Found:
If you are holding boost but not what you expect then it probably isn't a boost leak.
Right now I peak at 16psi and hold at 12psi and if I go WOT in 4th gear I throw that code.
My shop check the car for leaks and didn't find any. They said that if I can hold 12psi for a while at high RPM there is no leak. If there was a leak the pressure would have opened up the crack and evacuated already.
APR wants me to go back to my tuner Monday to check and reload the programming.
on apr stage I and do feel some "flutering" someimtes when i WOT. feels like air is sputtering into whatever hose or wherever the air is supposed to go. Thats y i was searching for Jet's T.I.P. was thinking mine was giving up or something.
dont belive it's leaking. i should try dropping it to stock and wot. we'll see. i just cleared it but never tested it. i got about 5k till i go out of warranty
When I had stage 1 I had a power drop above 5000rpm what was actually picked up on the dyno. When I went to Stage 1+ software the problem went away.
I don't know if that is the same problem you are getting but if you are holding boost then you don't have a leak. Everyone I spoke to that ever had a leak tells me it is a very obvious condition to feel.
Your pod shipment was delayed as PG ran out of white LEDs for the boost gauge. They got them back in stock and your order should have been shipped Friday.
cuz i didn't have injectors or it was heat soak. sometimes it would show up, somtimes not that's why i've lived with it and assumed it was because of the above items. this was my first check light due to boost.
didn't even get a cel/engine check light when i blew off a hose near my turbo at about 30k. wondering if that part is acting up.
all good on the pod. waited this long
on the car cuz i wanted that error code to come back. tore it up as best i could. 0-80 as fast as i could from a dead stop and 80+, wot at low/high speeds, etc...nothing. error code did not come back.
58 degrees outside might have helped it breathe better but even then no code.
guess i'll read up on it just in case and do some research as well as prep for a problem...tx for the headsup
That block is RPM, engine load%, requested boost, actual/achieved boost pressure.
Make any other changes or do maintainence before the CEL?
I have tried many things to try fixing this issue and I've had no luck. The funny thing is my car drives/feels fine, but this code continuously pops up without fail. Here are a list of things I've done so far:
1) Replaced all boost hoses with the high performance Samco hose kit.
3) Checked every clamp within the boost system.
2) Serviced my Hyperboost DV (Cleaned out old grease, and put in new grease.)
3) Replaced stock N75 Wastegate with N75-J.
4) Changed spark plugs to high performance copper plugs.
Any advice from anyone would be appreciated. Thanks!
