Help! Engine noise through speakers!
Well I just spent a load of bucks on Diamonds Hex separates, Arc Audio amp, and a sub. Sounds crazy and awesome. But there's that nagging engine noise through speakers. I have the factory head unit and the guys at La Jolla Audio still hasn't got it right...the noise is still there. They just spent the whole day trying to figure this one. Anyone have suggestions on how to get rid of this? I want to keep my factory head unit and plus I have no more dough for a after market unit. Can anyone help or have experience with this?
I had the same problem, got it done at future shop. had to get the amp taken out and kept the rear speakers in. They couldn't figure out how to get rid of the noise.
a bunch of powered wires that are interfering. Make sure the ground is at least as big as the power wire too. also check to make sure your RCA's aren't running next to powered wires either. I bet thats the problem.
Thanks 4PLAYA, I will ask those guys on Monday. But these guys are supposed to be experts, they should know this...right?
Make sure the signal ground is at the same point as the radios ground, NOT just a common ground.
This might involve running a separate ground wire back to the amp depending where they tapped in.
If they used one of those speaker to line-level converters (hopefully a good one) then make sure thats grounded properly also.
carl viking
40
07-12-2024 02:45 PM
ZPA117
A4 (B8 Platform) Discussion
09-08-2015 11:55 AM
audijim113
09-03-2015 01:22 PM
stormchaser1967
09-02-2015 12:47 PM
