HELP! Fluid will not flow to rear brakes!
I recently replace my rear rotors and pads. Unfortunately, I had to disconnect one of the rear brake lines. Now, when I tried to bleed the brakes no fluid is pumping to the rear lines. Front lines are bleeding fine. Anyone know why this would happen? Please help!
You know that the brakes are diagonal connected, right? That is, the front left and rear right are connected together, and the front right and rear left are connected together.
The manual states that 2 bar or about 30 psi is needed to bleed the system properly, and recommends pressure bleeding only, but does mention using the pedal as well.
I have not. I have a vacuum bleeder, but no pressure bleeder. I assumed (incorrectly?) that a pedal bleed would be fine. My helper accidently pumped the clutch, then the brake while the master cylinder was open. Could that affect things?
fluid through the ABS hydraulic controller. So, vac at the wheels won't cut it. You can try pumping the pedal down, then opening a rear bleeder screw, then closing the bleeder again before allowing the pedal up. An inexpensive pressure bleeder should be available at better parts stores, or maybe Sears has one. If you can get hold of a second reservoir cap, a pressure bleeder can be made from a yard sprayer.
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
ajg617
09-06-2015 07:23 AM
