Help with VAG COM....
#12
Tried it again today. Put it on (11788 + 64) = 11852 and I still can't get the sunroof to open with the remote -- only close. Very strange. You say you've gotten it to work on an 02 before Jason? I wonder what the difference is.
As per the nuances in the Ross-Tech guide, I hadn't thought of that before. But you're right, why can you do it in the key-lock without recoding to turn on channel 62? That's very odd. I wonder what's all behind this.
Well, any other suggestions for getting it working?
#13
AAAAAAAAAAAAAAAHHHHHHHHHHHHHH
Has anyone been able to get the moonroof open with the remote???
Just to be sure.. has anyone been able to get the scales to stay on all the time and have fog lights work by themselves.
Only reply if you have done it to a 02 A4.
Thanks for all the input guys/gals.. I just wish it would work properly..
Much appreciated
Much appreciated
#14
What, specifically, did you have to do to get it to work? Did you have to do anything related to the "Adaption 60,61,62" as listed in the Ross-Tech info?
#15
I just went down and checked it again and all you need to is change ch19 to 31000. I even tried some of the other combos and they all worked.
I did not do anything to 60,61 or 62.
I also tried to get the sunroof to close with remote but still no luck. Seems like there is no diffrence between coding it to 95 or 255. Maybe tomorrow I will try other values.
BlackQuaTTro225
08-16-2007 12:57 PM
