Hesitation after APR "+" upgrade?
It's really starting to get annoying.
Just upgraded from APR stage 1 to the "+" program with the Bosch injectors.
My car runs great, idle is smooth, pulls harder at highway speeds and seems to have less lag.
Now for the problem; When the engine is not fully warmed up(needle at the 12 o'clock), the engine surges/hesitates between shifts when the RPM drops bellow 2K, especially between 2nd and 3rd gears. I find myself shifting at much higher RPM's to avoid the stumble = not good for a cold engine. Could I have a faulty injector dumping too much fuel cold? I did a few logs and didn't notice anything unusual, any ideas? Oh, and the problem is even more pronounced when I switch to the stock program.
Currently running;
APR stage 1+
ER FMIC
EVO BPV
APR Snub mount
Currently running;
APR stage 1+
ER FMIC
EVO BPV
APR Snub mount
I have the APR home programmer, if I switch back to the stock injectors and stock programming the hesitation goes away. Could the spark plugs be to cold to handle that much fuel cold? They are stock plugs with +/- 15K miles on them.
you realize that rough idle you speak of was the precursor (about 2 weeks) to a coilpack failing. I surely hope you have a set of "R" new coilpacks or Hitachi "E"'s in there.
whats wierd is when the coilpack failed it idled fine then on boost misfired 100%.
no other mods to car other than SS DV
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
