HEY! The baby Jetta's in trouble!
OK. I changed the oil in the Jetta. When I put the plug back in, I forgot the washer ring. The new oil was already in when I discovered this. So, I backed the plug about 1/2 way out, snipped the washer so I could get it around the plug. Squeezed it together with needlenose'. AND NOW I'M LEAKING OIL FROM THE OIL PLUG. Just a little, but wherever I park, a 4-5 " spot. My new driveway! Ouch! I have a new plug and washer, should I change it?
Thanks!
Thanks!
yeah swap it quickly and you should be fine....
maybe get gloves and (assuming you're doing this while the engine is cold...obviously this wouldn't work too good with a hot engine) like stick your left thumb in the hole to keep the oil in there while you get the plug and gasket in
vansoffyomama
09-28-2015 04:38 PM
craigandjenn4
Q5/SQ5 MKI (8R) Discussion
09-27-2015 01:57 PM
havocgb
09-25-2015 04:50 PM
