hmmm Hitachi coil pack failure? going about 60 and CEL starts flashing, losing power and vibrations
But considering the transitory nature of the event, it's likely the symptoms were caused by a different means. It will be interesting to see what DTC's exists in this case.
<center><img src="http://pictureposter.audiworld.com/119821/evansa4.jpg"></center><p>Dealer had to come tow the car from my drive way.. better get her fixed before that happens
The DTC is unspecific, but if it was a coilpack, then the misfires by cylinder #, would be recorded. With the DTC that was stored, listing no unique cylinder/s, then all of the cylinders where likely involved, and it was not an ignition related misfire. Maybe a fuel delivery glitch, or something associated with the charge air supply or MAF meter, or IAT sensor, Or??? If it happens again, try and catch the ECU Freeze frame data associated with the symptoms.
