How do I add an Amp and replace all Speakers if I have a Symphony II
...including adapters and plenty of 8E0 868 243 door panel clips.
One head scratcher I forgot to mention is when you plug the panel harness back into the door controller. You have to pull back a latch to disconnect it in the first place. Well it has two locking notches. If you don't swing it all the way back when you push the connector back in, it catches the wrong set of tabs and doesn't connect. No door lights; no door switches. Make sure it's all the way back, push the connector in, and then swing the latch all the way, snapped closed. Push the door lock switch to wake up the controller. If you're hooked up right, you'll hear the lock cycling and see the door panel lights turn on.
Good luck!<ul><li><a href="https://forums.audiworld.com/audio/msgs/27508.phtml">My 2002 A4 speaker install</a></li></ul>
ECS Tuning-Audi
Q5/SQ5 MKI (8R) Discussion
11
02-24-2023 12:58 AM
xkahn
02-08-2018 10:43 AM
LaserSVT
64
01-19-2016 04:26 PM
carl viking
09-05-2015 05:31 AM
