how do i install an aftermarket headunit?
have a 2004 with the single din concert series headunit. the front speakers are powered by the head unit iirc and the rear speakers and the stock sub are powered by an amp in the rear. i have an aftermarket headunit and im wondering how i should do the wiring...
any ideas?
im totally lost...
so far ive connected the wires to the front speakers but i dont know how to wire the rear speakers...
any ideas?
im totally lost...
and tap them into the stock amp's output wires for rear speakers. as for the sub, i'd suggest just getting an aftermarket amp and sub(s)
I think changing the HU is more complicated than adding amps and subs. I added a sub to my stock system last weekend. It's added bass, but I miss how clean the system was from my last car.
I figure if you're gonna change your HU, change the rest! I think you'll be much happier with the outcome because the stock speakers aren't really worth keeping.
in that case though, get a decent enclosure, 1 10" sub that's rated at around 200W RMS or so (MTX RT10 comes to mind as a decent choice) and a cheap 2 channel amp, and use that. if you shop around, you can get a decent setup for under $100 that still leaves you plenty of room to upgrade in the future and is still better than the stock sub
my question is how do i get the rear speakers to work? i know how to wire the front speakers but the wiring for the rear is different...
figure out which wires go from the amp to the rear speakers (it'll be two pairs, but i don't remember which colors they are now, sorry) those are speaker-level wires that you can tap directly from the speaker-level outs of the head unit (ok you'll need to run wires to the trunk, but the point is, no adapters needed)
