How do I remove the front bumper??
Some old guy reversed into me a few weeks back & although there's not much damage to bumper, it has popped off at one end & I can't simply puch it back in.
I figured if I took the whole thing off then I could figure out how to get the end to go back in.
Thanks.
Thanks.
the only hard part is the bolts inside the bumper. Best way to get to those without a lot of work
is to turn a wheel inside, pull the wheel liner back and wedge your arm in there (helps to have an extension) and if my memory serves me correct, I think there are 3 or 4 10mm bolts on each side of the bumper where it bolts to the inside of the fender. It has been forever and a day since I have messed with an OEM bumper, but for some reason I *think* you might have to pull the lower center air dam out and there are 2 larger bolts that go through the bumper beam. Then pick off all of the obvious screws and you are golden.
check this link and scroll down a bit...
<ul><li><a href="http://www.audiforums.com/m_555370/mpage_1/key_/tm.htm#558431">http://www.audiforums.com/m_555370/mpage_1/key_/tm.htm#558431</a</li></ul>
I dunno, it seems to me to be easier to leave the headlights in and avoid dropping a screw
on the back side and have to fish it out. But I only took my bumper off maybe 10 or 15 times.
Audi A8 2005 Audi A8L
Jan_PL_S6
12
11-27-2015 07:27 AM
abpuma
09-17-2015 11:39 AM
Zumkopf
09-10-2015 05:23 AM
xkahn
New Member Welcome Area
09-05-2015 06:20 PM
ECS Tuning-Audi
09-01-2015 08:27 AM
