How do I replace the front door speakers? (2002 A4)
I searched and surprisingly turned up nothing on this subject, but how do I replace the front door speakers?
I was able to remove the trim and some screws, but nothing budges.
On this note, how do I go about replacing the rear speakers?
<center><img src="http://i132.photobucket.com/albums/q33/x1rider/door13.jpg"></center><p>as far as I know, you have to remove the inner door trim to unscrew and disconnect the speakers (I might be wrong).
Pop off the plastic cover by the armrest and remove the 2 screws under it.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door6.jpg">
<img src="http://i132.photobucket.com/albums/q33/x1rider/door7.jpg">
Unsnap and pull off the door trim.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door8.jpg">
Remove the screws underneath the trim.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door9.jpg">
Remove the screw (only one I think) at the bottom of the door.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door10.jpg">
Pull off the trim at the top, by the window.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door11.jpg">
Detach the door handle cable, and you should be able to remove the inner door lining.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door12.jpg">
Then you can unplug the speaker, unscrew and remove it.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door14.jpg">
<img src="http://i132.photobucket.com/albums/q33/x1rider/door24.jpg">
I don't think I forgot anything!
carl viking
40
07-12-2024 02:45 PM
N'Syncro
33
02-16-2020 03:12 PM
LaserSVT
64
01-19-2016 04:26 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
