I apologize a million times in advance, this has nothing to do with the B6 A4 but...
there are so many awesome DIY'ers here that I thought I would ask...
My girlfriend finally got her Jetta back after a month and as I was admiring the horrible gaps between the non-OEM fender, non-OEM bumper cover, and non-OEM hood, I heard a noise coming from the engine bay. I asked her to pop the hood, looked down on the passenger side and saw that the AC compressor pulley is not running true. The 2.0 engine is a transverse layout so the pulley is right by the fender that got smashed in, I figure the pulley got hit. My question is, is there any adjustment for the pulley or will I have to change it? (there's no way the car is going back to the body shop)
Thanks everyone and my apologies again.
I'm sure you'll get it done on your own but...
I sure as heck would make the body shop fix it. When I got my a4 back; a month or so later now, i'm leaking washer fluid at the pass. side headlight washer. I took it back, and since it's a "slow" leak and not gushing, they said they'd need the car for a "few hours." Well, they are getting it for a "few hours" to fix what should had been done correctly the first time.
Just wanted to add:...
The impact that bent the pulley may have effected the A/C compressor also, not that is has necessarily, but it's possible that after some use a defect may appear involving the shaft seal or bearing. If you take up the pulley problem with the insurance co., a case could be made in argument for a new compressor assembly.
