I just installed my Phat Box from my B5 to my B6 with this cable from Ebay seller...
<center><img src="http://pictureposter.audiworld.com/44415/phat_box_cable.1.jpg"></center><p>Everything works fine. I would have done a write-up with pics but my digital camera is broken. This particular cable is loose on the ends as you can see. Just follow the instructions of where to install each color wire to match the numbered pin location on the back of the symphony II harness (won't need the blue harness). It would be easier if you could get your hands on the tool that they use to insert these ends into a harness. I just used a pair of needle nose plyers. I wouldn't suggest using them because you can damage the wire ends when you try to press them down. The other end of the cable will connect to your Audi PhatBox cable that came with the unit. So after install, this will give you a trunk cable for a CD changer like they had in the B5's.
I may be wrong, but I think I'm the first to install a Phat Box in the trunk of a B6. All the other posts I read installed in the glove and I didn't like that install. I'll post pics as soon as I get my hands on a new camera.
This cable may take a while to get to you because it's coming from Poland via the post office. Took me 2.5 wks but well worth it. I highly reccomend the seller and the product.<ul><li><a href="http://cgi.ebay.com/NEW-Audi-CD-CHANGER-PHATBOX-Lead-CABLE_W0QQitemZ120056500774QQihZ002QQcategoryZ1277 27QQssPageNameZWDVWQQrdZ1QQcmdZViewItem">http://cgi.ebay.com/NEW-Audi-CD-CHANGER-PHATBOX-Lead-CABLE_W0QQitemZ120056500774QQihZ002Q
uble1234
14
10-23-2020 08:07 PM
N'Syncro
33
02-16-2020 03:12 PM
xkahn
02-08-2018 10:43 AM
