I seem to be slowly losing coolant, and I notice a burning smell after driving...smells like coolant
Old 02-20-2008, 03:50 AM
nvr_follow's Avatar
Default I seem to be slowly losing coolant, and I notice a burning smell after driving...smells like coolant
but no sign of dripping or leak....any thoughts? Coolant level was well above max and is now at min (took a year to get there, but I think it happened within the last few months)
Thanks!
Old 02-20-2008, 04:24 AM
CowtownDub's Avatar
Default You may want to check your coolant flange.
That's where mine was leaking.
Old 02-20-2008, 04:31 AM
AudiWorld Uber User
Tgr_Clw's Avatar
You're absolutely positive you're smellling coolant and not oil?
nvr_follow's Avatar
Did you see any puddle or sign of leaks under car?
Old 02-20-2008, 04:32 AM
nvr_follow's Avatar
Default I know my VC gasket needs to be replaced, and may be dripping down causing smell, but this smells
like coolant. Isn't oil more like a burning rubber smell?
Old 02-20-2008, 04:36 AM
CowtownDub's Avatar
Default As it got worse I did.
Originally, I only noticed the smell. If you look between the firewall and the back of your head, look for coolant leaking down the head onto the transmission. A flashlight and a small mirror will be helpful.
Old 02-20-2008, 06:11 AM
AudiWorld Uber User
Tgr_Clw's Avatar
Default Sort of. When I had a VC leak it smelled like some sort of fried food (not rubber).
Burnt coolant smells sweet.
Old 02-20-2008, 06:48 AM
GDawgA4's Avatar
Mine had a big puddle! All the coolant leaked out overnight when my flange went.
GDawgA4's Avatar
My burnt coolant does not smell sweet, that's for sure!
Old 02-20-2008, 06:49 AM
scorneil's Avatar
Default also check your radiator - just replaced mine
eventually had puddles but didn't for the longest time - leakage probably blew off while driving.
refilled coolant twice before i fixed it (would take maybe 2 months to drain)
Quick Reply: I seem to be slowly losing coolant, and I notice a burning smell after driving...smells like coolant
