Ignition Problem Bad coils maybe
I had a code coming up (16685) cyl misfire, I was checking the coil packs on my 2002 audi a4 1.8T. I checked each individual coil for spark while engine was on, i noticed that the engine began to knock and then it died. After putting the coils back the engine will turn on and shake then die. Ive also noticed a smell of gasoline, any ideas?? My codes jumped from 3 codes to 12 after mishap. Maybe i flooeded the engine, do i just wait and trying again later?
16712
P0328 Knock Sensor 1 Circ High Input
17734
P1326 Cyl.2-Knock Contr. Limit Attained
16684
P0300 Random/Multiple Cylinder Misfire Detected
16685
P0301 Cyl.1 Misfire Detected
16716
P0332 Knock Sensor 2 Circ Low Input
17763
P1355 Cyl. 1, ignition circuit Open Circuit
17772
P1364 Cyl. 4 ignition circuit Open Circuit
16688
P0304 Cyl.4 Misfire Detected
17769
P1361 Cyl. 3, ignition circuit Open Circuit
16687
P0303 Cyl.3 Misfire Detected
18010
P1602 Power Supply (B+) Terminal 30 Low Voltage
16705
P0321 Ign./Distributor Eng.Speed Inp.Circ Range/Performance
16712
17734
16684
16685
16716
17763
17772
16688
17769
16687
18010
16705
I'm not a big fan of Hitachis. I ran them for several months but at the end reinstalled the OEM "R" versions.
My car ran excessively rich with Hitachis and fuel economy was noticeably worse.
Installed new spark plugs and new r coils. Car starts up and runs great. The knocking noise is still present though, im aproaching 140k so im taking it to the dealership and installing the belt kit with a new water pump, maybe that will solve that. Been thinking about obtaining new knock sensors maybe that helps as well. Dealer is charging 550$ for job seems pretty good to me. Audi dealership is in Mexico though, I live right at the border
. Well wish me luck.
Alexandroff
11-21-2017 01:45 PM
anticsAK
09-06-2015 05:34 AM
anticsAK
09-04-2015 09:59 PM
