I'm officially throwing caution to the wind... my overall mod plan & some pics (long)
I had been waffling for some time between keeping my A4 largely stock because I've been concerned about it's reliability (random electronic issues, power steering pump, etc), but I've decided to pursue a relatively comprehensive (albeit not too over-the-top) mod strategy, designed to enhance the overall performance of the car while still keeping it streetable and comfortable. As you can see, the majority of my mods are brake-oriented, because I felt the stock brakes were woefully inadequate, and now that I have the S4 brakes, I need to shift the braking balance further to the rear of the car (and get some proper pads for all 4 corners). Also, as you can see, I'm rather cautious about any powertrain mods, but I am considering either APR stage 1+, with the fuel injectors, or the more serious but twice as costly K-04/E05 route (which also requires a clutch almost immediately, something that APR 1+ will not for some time). My overall goal is a car that will be satisfying to drive on the street, and will perform well at autocrosses and maybe 4 or 5 track days per season. One of the most obvious mods you'll notice is absent from my list is springs and shocks- While I do feel that the stock sport setup has too much vertical motion, I'm waiting until my stock setup wears out before considering replacements- The sway bar should help tie the rear corners together and firm things up anyway, and will provide a much needed shift in the overall cornering behavior of the car from serious understeer to mild understeer (or even hopefully neutral, with some tire pressure fiddling). My primary concerns are handling and braking, but just like everyone else, I am tired of being beaten by every hopped up Civic or Corolla S I see. Anyway, those are my somewhat disorganized thoughts, and any commentary is welcome. (And yes,I know there's not much attention paid to the look of the car, but that's not really my thing. Wheels/wing/door blades is all I need.)
DONE (chronological order)
Hardwired Valentine One
Neuspeed Short Shifter
Ebony "Euro" shift **** (not really a mod, I know)
Neuspeed snub mount
S4 front calipers w/ stainless lines & stock pads (with caliper paint and Audi rings)
S4-size 320mm slotted, cadmium-plated ECS front rotors
Topspin design 4-point harnesses (1 installed, 1 ordered)
Topspin design CF harness brackets (ordered)
Neuspeed rear sway bar (uninstalled)
PLANNED (no particular order)
Kosei K 1 TS 17x8.5inch, 15.5lb wheels $880
Spoilerdepot B6 S4 spoiler (painted) $225
ECS 3.0L rear slotted rotors(245x10) $120
ECS rear stainless brake-lines $80
ECS HP brake pads, front $100
ECS HP brake pads, rear $40
Neuspeed Exhaust $850
B6 S4 door blades $280
OEM TT225 "710N" Diverter Valve $30
ITG/K&N panel air filter $40
B6 S4 power steering pump/cooler $?$$$
THE BIG STUFF
Greedspeed Twin IC kit $650
WITH EITHER
Greedspeed E-05 Turbo Upgrade Kit $2150
AWE Tuning Stage 2 Clutch $500
OR
APR Stage 1+ ECU & injectors & $1000
Flipswitch EMCS $130
<img src="http://pictureposter.audiworld.com/34219/img_0879.jpg">
<img src="http://pictureposter.audiworld.com/34219/oncar.jpg">
<img src="http://people.brandeis.edu/~tsle/harness.jpg">
<img src="http://people.brandeis.edu/~tsle/911.jpg">
<img src="http://people.brandeis.edu/~tsle/gas.jpg">
Neuspeed snub mount
THE BIG STUFF
WITH EITHER
OR
Move the clutch up the list
I can't speak for anyone else.... but my clutch can't even hold the torque of the GIAC or neuspeed chips. I've never launched it or cooked it, but it chatters when the torque peaks.
about the exhaust...
Want to trade exhausts, Neuspeed for stock + a few bucks? I am in Lexington, MA and I am starting to put my car back to stock. This could be a good opportunity for both of us. Shoot me an e-mail if interested. shamel@h-m-inc.com
i never got em on.
i bought them off of AW classifieds... when they were being mounted by a friend, he noticed that they were missing a quite large and important bolt. so i haven't had the chance to use the calipers, rotors, or lines yet. just chillin in my basement. you interested?
