installing a Dension ICE iPod
I'm going to install the DICE iPod on my Symphony tonight in my 02 A4 1.8t. Any advice before installing or anything to look out for? Also I have two radio keys... Should i be using four keys? Thanx.
...but it is advised that you disconnect all of the cables from the headunit. It just makes it easier to work on the headunit because all of the attached cables are short. Once you've disconnected/reconnected the cables your headunit will be in safe mode. Make sure you have your radio code handy and follow the instructions in your manual to re-enable your headunit.
Also, I set the dip switches to be in ipod mode, not dice mode. It does not transfer the song and playlist numbers correctly, but it accesses them quicker and I found the ipod mode to be less buggy.
fish the hanger through (or fish if you have) then just tape one end of the cable to it and pull. You can put your hand in there to help make room so it comes through nicely and there is plenty of room. Mine comes out on the driver's side and not the passenger side, but there is enough space on both sides.
