Intake air temperatures - actual readings (and why cones aren't the way to go)...
#21
i've been meaning to work on it more, but i havent found the time. i want to sandwich insulation between this and another piece of sheet metal for the heatshield, and also need to work on some bends
basically its a cone filter, aluminum piping, rubber bend,connected to maf. the filter sits WAY down low away from the engine compartment and the engine and turbo will be red hot but the cai will be ambient, or ice cold at night if it gets really cold air flowing through it.
<img src="http://scf.usc.edu/~alexancl/car/cai.jpg">
<img src="http://scf.usc.edu/~alexancl/car/cai2.jpg">
<img src="http://scf.usc.edu/~alexancl/car/cai3.jpg">
#23
if nothing else this "drop in heat shield" is 100x better than the thin, measly stock POS.
it doesnt matter what kind of intake u believe in, i think we can all agree that the stock heat shield is crap.
#29
"Secondly, launching from a set of traffic lights in a car equipped with an exposed under hood cone intake could be giving the engine very hot inhalations" An airbox wouldn't be much better in this situation..
#30
Admittedly that could be worse case but it clearly points to cones as an unsuitable solution - particularly when they're on the same underhood side as a turbo.
