Intercooler chillers? Anyone running one of these systems?
I guess this would be better suited for people w/ FMIC. I sure could use an extra 50hp!<ul><li><a href="http://www.machv.com/ntercooler.html">http://www.machv.com/ntercooler.html</a</li></ul>
<I>Ford's patented SuperCooler technology cleverly provides a special burst of power for the SVT Lightning concept. Traditional intercoolers dissipate heat from the supercharged air by circulating coolant through a front-mounted, air-cooled radiator. With the SuperCooler system, the vehicle's air conditioning system is used to chill a small storage tank of coolant to about 30 degrees Fahrenheit.
On demand, the SuperCooler system switches the intercooler flow from its normal circulation and dumps the chilled coolant into the engine's intercooler. In turn, the intercooler dissipates up to 20 percent more heat from the charge air - resulting in a denser air charge.
A green light on the instrument panel indicates the system's readiness. SuperCooler is activated automatically when the driver depresses the accelerator to a wide-open-throttle position.
"This technology plays directly into the hands of the enthusiast," Coletti says. "The SuperCooler provides the edge for the driver, and it is done simply by taking advantage of the hardware that already exists in the vehicle."
As a result of this cool technology, the SVT Lighting concept can give its driver as much as 50 transient horsepower for short bursts of 30-45 seconds and regenerate within 2 minutes under normal driving conditions. While its effect is similar to that of an aftermarket nitrous oxide system, the SuperCooler is completely self-contained, environmentally friendly and regenerative.</I><ul><li><a href="http://www.autonews.com/files/2003_detroit/ford/svt/svt.doc">http://www.autonews.com/files/2003_detroit/ford/svt/svt.doc</a</li></ul>
<center><img src="http://www.alfacentro.com/features/callaway/images/engine.jpg"></center><p><ul><li><a href="http://www.alfacentro.com/features/callaway/">Greg Armstrong - forced induction expert</a></li></ul>
some one should come up with the same system for the intake box or aftermarket filter....a highly cold conductive tube maybe copper that u can shoot cold NOS or some other gas threw that keeps circulating while running. the tubing can go in the air box where the air passes threw but before the filter ......think i might make something haha should be easy think about it would be like driving the car 30 degree weather in the middle of the HOT summer here in FL any comments .............?
over the long term, so that unit had already come apart a few times. I think a different unit was installed later after development was done. Greg turbo-charges Lamborghinis as his main business. His shop is a candy store of high end tuner stuff.
N'Syncro
33
02-16-2020 03:12 PM
raiderrider
12
09-08-2015 05:46 AM
S4intheOC
09-08-2015 12:12 AM
