I've bought a set of Hawk HPS pads (f+r)...
AudiWorld Uber User
Should I think about replacing the rotors as well or I'll be okay for 15k-20k?
My oem fronts have about 5k and rears has 30k.
I installed PBR Ceramics, and they touched more of the rotor surface than the stock fronts pads did. My stock pads left a little ring of rust on teh disc face on either side of the pad. As a result, that (approx.) 1/8" band of rust that goes around the inner diameter of the disc face caused vibrations and squealing when teh new pads touched it.
Local shop didn't reccommend turning the disc face as the rust also had little pits.
So, I just bought new rotors, and things are smooth and quiet now.
I'd replace the rears now. They get a lot of use with ESP, so you may as well have new pads and rotors back there from the start. You'll like the HPSs
N'Syncro
33
02-16-2020 03:12 PM
mkirkpatrick
Wheels & Tires Discussion
09-03-2015 08:31 AM
