I've got a few SB clutch questions about the OFE series.
If I'm reading their chart right, Stage 3 is the OFE HD, correct? Torque capped at 300 for AWD. And
OFE SS (the popular one here it seems) would be Stage 4? Torque capped at 480.
When my K03 goes I may go BT (GT28RS). Thinking for the future, the OFE SS would probably be a better choice to hold the extra power if I do go BT. Or would the HD be enough to hold the torque? The only info I found was a Revo file GT28RS from the B6 forum with a dyno sheet showing 284 AWTQ.
Still deciding between the dual mass or light weight. So far 9 out of 10 posts I've seen with the heavier light weight (20 lbs) have seen some chattering which is expected I suppose. But being this is my daily, don't know if I want to deal with chattering.
Genuine Audi Parts has the OE DMFW for $572.
Thoughts? Advice?
Thoughts? Advice?
You would be fine with a Stg3 on a 28rs... I like the DMFW with stock motor because it is quite (chattering is only at an idle really) and easy to drive around the city, don't need to blip the throttle or rev as high when starting off like you will with the LWFW.
That being said, it never hurts to buy a clutch that can handle a little more power if you can afford it...
Who are you looking to buy through?
with it. I would stick with the stock FW, just get yours resurfaced from Southbend for $20 and you're good to go. If you don't want any downtime just get a used one, uh...like mine =) and ship it to them.
flywheel then maybe send my flywheel to SB to resurface and sell to someone, if it's in resurfaceable condition.
