I've STFA, and temp gauge saga continues:
3 codes thrown:
17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
P1564 - 002 - Lower Limit Exceeded - Intermittent
16891 - Idle Control System RPM: Higher than Expected.
P0507 - 001 - Upper Limit Exceeded - Intermittent
17095 - Transmission Fluid Temp Sensor (G93): Implausible Signal
P0711 - 003 - Mechanical Failure - Intermittent
Can the Transmissions fluid temp sensor cause temp gauge misreadings and idle fluctuations?
There seems to be very little about the trans fluid temp sensor - where is this sensor even located?
iamdrewseph
10-01-2015 11:33 AM
