Just installed the awe gt28r kit, lots of pics...
Stock turbo and cat out with new motor mount. Starter wires covered with heat shield tape.
<img src="http://pictureposter.audiworld.com/38067/pc290033.jpg">
<img src="http://pictureposter.audiworld.com/38067/pc290034.jpg">
Stock exhaust mani with old gasket used as a template for gasket matching. Kit comes with new mani and cat to dp gaskets.
<img src="http://pictureposter.audiworld.com/38067/pc290036.jpg">
close up of one of the four ports.
<img src="http://pictureposter.audiworld.com/38067/pc290041.jpg">
Here's the finished product.
<img src="http://pictureposter.audiworld.com/38067/pc290052.jpg">
close up of gasket matched ports. Pics of the turbo side was blurry but it was also matched.
<img src="http://pictureposter.audiworld.com/38067/pc290042.jpg">
<img src="http://pictureposter.audiworld.com/38067/pc290043.jpg">
Pre assembly of gt28r, exhaust mani, and high flow cat with oil/coolant lines.
<img src="http://pictureposter.audiworld.com/38067/pc290050.jpg">
<img src="http://pictureposter.audiworld.com/38067/pc290058.jpg">
<img src="http://pictureposter.audiworld.com/38067/pc290059.jpg">
<img src="http://pictureposter.audiworld.com/38067/pc290060.jpg">
<img src="http://pictureposter.audiworld.com/38067/pc290061.jpg">
John @ AWE was nice enough to give mr the ITG panel filter instead of the free pedal set:-D
<img src="http://pictureposter.audiworld.com/38067/pc290062.jpg">
So far so good, just some minor adjustments of the DP rattling against the cross member.
That was a tip from another AW member. But my car only has 20k miles so all the bolts were in pretty good shape.
I have had the GT28rs for about 40,000 miles and ran with stk exhaust manifold, Nuespeeds manifold, (which cracked) and now using ATP's. With larger injectors and a lot more boost, (I'm running 24 psi) stk exhaust manifold really doesn't handle extra exhaust to the turbo well. It develops "scavaging" within.
I assume your have a FMIC or DSMIC. Increasing boost and timing and then doing your data logs will wake up this system. So many send software that is too mild for car and they need to be adjusted.
Since I had my 02 b6. Been bugging Mike at AWE when it's gonna come out and was told that this kit is gonna be in stages but all modular. Acording to AWE, for this kit the stock exhaust mani is enough.
So far so good. Engine fired right up no cel/check engine light. Just got the DP adjusted for fitment and I will be out enjoying this kit today;-D
