Just installed Parrot CK3000 Bluetooth kit....works great!
#13
that's it. Your blitzsafe will work fine since it uses a different connector.
#14
to tap into the battery, ground, and ignition lines going to the phatbox unit (or remote glovebox CD changer harness).
#15
this unit is more discreet. It allows you to send contacts from your phone to the unit to be stored. You put voice tags with the entries into the Parrot unit, so your phone doesn't have to support voice tags. Also it has "magic words" so it can be voice activated at any time, so once it's setup you won't need the switch.
I plan to set it up this way and hide the switch. The only thing you'll need out is the microphone, of which I mounted on the steering column shroud.
#16
speaker phone. It has voice activation and you can voice dial once you have your address book set up in the unit.
#20
and here it is in PaulW's A8:<ul><li><a href="https://forums.audiworld.com/a8d3/msgs/14428.phtml">https://forums.audiworld.com/a8d3/msgs/14428.phtml</a</li></ul>
ltooz_a6_a8_q7
14
04-12-2024 12:11 PM
xkahn
02-08-2018 10:43 AM
ltooz_a6_a8_q7
Q5/SQ5 MKI (8R) Discussion
12
11-29-2015 07:21 PM
xkahn
New Member Welcome Area
09-05-2015 06:20 PM
audijim113
09-03-2015 01:22 PM
