just put stock head unit back in but...
Old 06-22-2004, 03:37 PM
Hyperspeed--'s Avatar
Default just put stock head unit back in but...
it doesnt turn on.. how odd.. its just 4 plugs right? 2 harnesses, 1 green thing and 1 antenna right? weird how its not turning on.. any insight?
Old 06-22-2004, 03:44 PM
Junior Member
modwad's Avatar
Default Was it your stock head unit? Or bought elsewhere?
I know my stock wouldn't work now because I had to move wires within the metra and stock harnesses to make the aftermarket work and ditch the K-wire also. I'd have to switch everything back in order to put stock back in.
If you don't come on in at least safe mode, you're having a power problem.
I realized after I took out my OEM and finished putting in my aftermarket (no ****, everything was all done) that I'd left 6 CD's in the stock head unit. So I hooked the stocker direct up to 12V and ground (no other hookups). It came on in safe mode, but it was able to eject the CD's at least. Lucky...
AudiWorld Expert
Projekt 8E's Avatar
check fuses.
Old 06-22-2004, 03:57 PM
Turbo_Whip!'s Avatar
maybe a safety code is needed?
Old 06-22-2004, 03:58 PM
on the HU or in the fuse panel?
Junior Member
modwad's Avatar
It would still at least have power on the screen.
stock unit.. i go chk fuses
Old 06-22-2004, 04:21 PM
fuses are all good.. whats next?
Old 06-22-2004, 04:25 PM
Junior Member
modwad's Avatar
If you know which pins are which, hook direct 12V.. see if safe mode comes up.
just connect a direct 12v and grond source to the pins?
Quick Reply: just put stock head unit back in but...
