Keyfob BT: Changed battery on keyfob and no work.
It's the same type of battery, just new.
I tried the second keyfob (never used before). That works as a remote, but car automatically immobilised when I went to start it up. I switched batteries and neither keyfob buttons work.
Tried resetting the keyfobs as described in the manual (press button A or C and turning in driver's door within one minute), still doesn't work.
Any clues?
Thanks folks.
Any clues?
Thanks folks.
I had the same problem....you have to insert the fob you want to program into ignition and then turn to start..don't start car but dash should say push in clutch or something like that. then hold down the trunk open button or unlock, can't remember which button it is for 10 seconds. then it should work. remove key and presto!!!
stormchaser1967
09-02-2015 09:26 AM
