Latest charts from the COIL PACK failure questionnaires ...
<img src="http://pictureposter.audiworld.com/43918/my3html1.jpg">
<img src="http://pictureposter.audiworld.com/43918/my3html10.jpg">
<img src="http://pictureposter.audiworld.com/43918/my3html11.jpg">
<img src="http://pictureposter.audiworld.com/43918/my3html12.jpg">
<img src="http://pictureposter.audiworld.com/43918/coil_failure_conditions.jpg">
<img src="http://pictureposter.audiworld.com/43918/my3html13.jpg">
<img src="http://pictureposter.audiworld.com/43918/my3html2.jpg">
<img src="http://pictureposter.audiworld.com/43918/my3html3.jpg">
<img src="http://pictureposter.audiworld.com/43918/my3html4.jpg">
<img src="http://pictureposter.audiworld.com/43918/my3html5.jpg">
<img src="http://pictureposter.audiworld.com/43918/my3html6.jpg">
<img src="http://pictureposter.audiworld.com/43918/my3html7.jpg">
MANY FOLKS DIDN'T INCLUDE 'BUILD DATE' ON THEIR QUESTIONNAIRES. HERE ARE THE NUMBERS REPRESENTING THOSE WHO DID.
<img src="http://pictureposter.audiworld.com/43918/my3html8.jpg">
<img src="http://pictureposter.audiworld.com/43918/my3html9.jpg">
<img src="http://pictureposter.audiworld.com/43918/my3html14.1.jpg">
Here are the completed questionnaires (some not yet charted):
User account number (aid): 32799
Posted by lil4x4 on 2002-11-14 09:09:32
1. Car?
_X__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____e. Other (describe)
2. Where were you when you first noticed the symptoms?
_X__a. On the road
_X__b. Just after starting your car
____c. Other (describe)
3. What symptoms did you experience (check all that are applicable)?
_X__a. Shaking or excess vibration
_X__b. Engine warning light
_X__c. Rough idle
_X__d. Bad smell
____e. Excessively hot exhaust manifold
_X__f. Loss of power
____g. Other (describe)
4. What did you do when the failure occurred?
____a. Drove the car to the closest Audi dealer
_X__b. Drove the car home then had it flatbedded to the dealer
____c. Parked it and had it flatbedded to the dealer from there
____d. Drove it for a while until secondary symptoms made you park it and have it flatbedded to the dealer
____e. Other (explain)
5. Was safety a factor when the failure occurred?
____a. Yes
_X__b. No
____c. If Yes, explain briefly
6. What was the weather like when the failure occurred?
____a. Mild
____b. Hot and humid
____c. Hot and dry
____d. Mild with precipitation
____e. Cold with precipitation
_X__f. Cold but above freezing
____g. Cold and below freezing
____h. Other (describe)
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? _Western Ohio_______________
8. What was the approximate DATE and TIME of day or night that the failure occurred? _10/22/02___10:30_am_____________
9. What did the dealer do?
_X__a. Replaced the failed ignition coil
____b. Replaced all of the ignition coils
____c. Put in the latest rev coil(s)
____d. Put in the same rev coil
____e. Rev of failed coil(s) if you know (H, J, B, D, etc)
_J__f. Rev of new coil(s) if you know (H, J, B, D, etc)
____g. Coil that failed (#1, #5, etc)
10. What is your typical driving style?
____a. Gentle
_X__b. Moderate
____c. Aggressive
____d. Other (explain)
11. How many ignition coil failures have you experienced?
_X__a. One
____b. Two
____c. Three
____d. Information for all failures is imbedded in this one questionnaire.
____e. I filled out a questionnaire for each failure.
12. Have you noticed any secondary effects since the coil failure problem was corrected?
____a. Yes
_X__b. No
____c. If Yes please describe
13. Production date of car (inside drivers side door pillar): __12/01________________
14. Miles driven before failure: __19,400_____
User account number (aid): 39070
Posted by mkelsey on 2002-11-14 09:40:29
In Reply to: Sounds like it. Would you please fill out our coil pack questionnaire (help the cause) ... posted by Placitas NM Audi on 2002-11-14 08:00:56
HELP US PUT TOGETHER AMMUNITION FOR MAKING A FINAL COIL PACK (IGNITION COIL) FIX HAPPEN:
AUDI 2002, 2003 A4 IGNITION COIL FAILURE QUESTIONNAIRE:
1. Car?
__X__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__X__b. Just after starting your car
__X__a. Shaking or excess vibration
__X__b. Engine warning light
__X__c. Rough idle
____d. Bad smell
____f. Loss of power
_X___a. Drove the car to the closest Audi dealer
____b. Drove the car home then had it flatbedded to the dealer
____a. Yes
__X__b. No
____a. Mild
____c. Hot and dry
____f. Cold but above freezing
_X___g. Cold and below freezing
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? ______Midwest_________________
8. What was the approximate DATE and TIME of day or night that the failure occurred? _______11/14 7AM___________
_X___a. Replaced the failed ignition coil
____f. Rev of new coil(s) if you know (H, J, B, D, etc)
____a. Gentle
_X___b. Moderate
____c. Aggressive
__X__a. One
____b. Two
____c. Three
____a. Yes
_X___b. No
13. Production date of car (inside drivers side door pillar): _10/01___________________
14. Miles driven before failure: 8600_______________
User account number (aid): 32892
Posted by A4TITUDE on 2002-11-05 13:53:33
In Reply to: Here's the questionnaire. Please help us out by filling it out ... posted by Placitas NM Audi on 2002-11-04 09:07:37
1. Car?
_____b. 2002 A4 3.0
_____c. 2003 A4 1.8T
_____d. 2003 A4 3.0
_____e. Other (describe)
__X__a. On the road
_____b. Just after starting your car
_____c. Other (describe)
__X__c. Rough idle
__X__d. Bad smell
_____e. Excessively hot exhaust manifold
__X__f. Loss of power
_____g. Other (describe)
_____a. Drove the car to the closest Audi dealer
__X__b. Drove the car home then had it flatbedded to the dealer
_____c. Parked it and had it flatbedded to the dealer from there
_____d. Drove it for a while until secondary symptoms made you park it and have it flatbedded to the dealer
_____e. Other (explain)
__x___a. Yes
_____b. No
_____c. If Yes, explain briefly : I was in traffic when my car began shaking violently and power was greatly reduced. Just getting out of the way of traffic was challenging.
____a. Mild
____c. Hot and dry
__X__f. Cold but above freezing
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? ___Kansas City, MO________________
8. What was the approximate DATE and TIME of day or night that the failure occurred? ___Sunday, November 3, 2002 @ 10:15am_______________
9. What did the dealer do? Part number of replacement: 06B-905-115-J
_?___g. Coil that failed (#1, #5, etc)
____a. Gentle
__X__b. Moderate
____c. Aggressive
_X___a. One
____b. Two
____c. Three
____a. Yes
__X__b. No
13. Production date of car (inside drivers side door pillar): ____11/01___________
14. Miles driven before failure: ___6800____________
User account number (aid): 9160
Posted by QuattroRocket on 2002-10-19 00:14:52
In Reply to: If you've had one or more coil pack (ignition coil) failures, please open this posting: posted by Placitas NM Audi on 2002-10-18 21:48:58
1. Car?
_X___a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__X__c. Rough idle
__X__d. Bad smell
_X___c. Parked it and had it flatbedded to the dealer from there
_X___a. Yes
____b. No
#NAME?
_x___a. Mild
____c. Hot and dry
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? _Vancouver Canada
1st time: 8:30am in undergound parkade, 2nd time: 3:30pm in afternoon quite recently after parking briefly.
_x__a. Replaced the failed ignition coil
1st time: coil #4, second time: coil #2 & #4
____a. Gentle
__x__b. Moderate
____c. Aggressive
____a. One
____b. Two
_x___c. Three
____a. Yes
_x___b. No
13. Production date of car (inside drivers side door pillar): Aug 2001
14. Miles driven before failure: 15,000km's and then again approx 20,000km's
User account number (aid): 30344
Posted by Mat J on 2002-10-19 05:51:15
1. Car?
__X__a. 2002 A4 1.8T AVANT
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
____a. Shaking or excess vibration
__X__c. Rough idle
____d. Bad smell
____a. Yes
_X___b. No
____a. Mild
__X__b. Hot and humid, RECENT RAIN
____c. Hot and dry
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? __SE NEW ENGLAND_____________________
8. What was the approximate DATE and TIME of day or night that the failure occurred? ___7AM__05/09/02_____________
__X__a. Replaced the failed ignition coil
_J___f. Rev of new coil(s) if you know (H, J, B, D, etc)
_2___g. Coil that failed (#1, #5, etc)
____a. Gentle
__X__b. Moderate
__X__c. Aggressive
_X___a. One
____b. Two
____c. Three
__X__e. I filled out a questionnaire for each failure.
____a. Yes
__X__b. No
13. Production date of car (inside drivers side door pillar): _________02/02___________
14. Miles driven before failure: ____5401___________
User account number (aid): 45552
Posted by mhlilja on 2002-11-03 18:11:06
1. Car?
_X__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
_X_a. On the road
__X__c. Rough idle
____d. Bad smell
____a. Yes
__X__b. No
____a. Mild
____c. Hot and dry
__X__g. Cold and below freezing
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? ___Minneapolis_____________
8. What was the approximate DATE and TIME of day or night that the failure occurred? ___March02_________
____a. Gentle
__X__b. Moderate
____c. Aggressive
____a. One
____b. Two
__X__c. Three
____a. Yes
_X__b. No
13. Production date of car (inside drivers side door pillar): ______Oct 01____________
14. Miles driven before failure: ___7500________
Posted by mhlilja on 2002-11-03 18:19:59
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
__x__a. On the road
__X__c. Other (idling in parking lot)
__X__c. Rough idle
__X__d. Bad smell
__X__a. Drove the car to the closest Audi dealer
____a. Yes
__X__b. No
____a. Mild
____c. Hot and dry
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? ____Minneapolis_________
8. What was the approximate DATE and TIME of day or night that the failure occurred? ___Nov02_______
____a. Replaced the failed ignition coil
__X__H. Still in shop waiting for new revision of coils.
Old coils no longer available. Dealer has four other A4's
waiting for new coils.
____a. Gentle
__X__b. Moderate
____c. Aggressive
____a. One
____b. Two
__X__c. Three
__X_e. I filled out a questionnaire for each failure.
____a. Yes
____b. No
__X__c.Do not know yet
13. Production date of car (inside drivers side door pillar): ____Oct01__________
14. Miles driven before failure: ___17500______
Posted by mhlilja on 2002-11-03 18:14:39
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__X__c. Rough idle
____d. Bad smell
__X__c. Parked it and had it flatbedded to the dealer from there
____a. Yes
__X__b. No
____a. Mild
____c. Hot and dry
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? __Minneapolis______________
8. What was the approximate DATE and TIME of day or night that the failure occurred? _9/02____________
__X__b. Replaced all of the ignition coils
____a. Gentle
__X__b. Moderate
____c. Aggressive
____a. One
____b. Two
__X__c. Three
____a. Yes
__X__b. No
13. Production date of car (inside drivers side door pillar): ______oct01___________
14. Miles driven before failure: ______15000____
User account number (aid): 5511
Posted by Steve in VA on 2002-11-04 06:16:18
In Reply to: Sorry to hear about your misfortune again Steve. Could we get another questionnaire from you ... posted by Placitas NM Audi on 2002-11-04 00:16:16
9
1. Car?
____a. 2002 A4 1.8T
__x__b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__x__b. Just after starting your car
__x__a. Shaking or excess vibration
__x__b. Engine warning light
__x__c. Rough idle
____d. Bad smell
__x__e. Other Replaced coil
____a. Yes
__x__b. No
____a. Mild
____c. Hot and dry
_x___f. Cold but above freezing
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? ___Northern VA____________________
8. What was the approximate DATE and TIME of day or night that the failure occurred? ___11/3
4:00 pm_______________
____a. Gentle
___x_b. Moderate
____c. Aggressive
____a. One
__x__b. Two
____c. Three
____a. Yes
_x___b. No
13. Production date of car (inside drivers side door pillar): __11/01__________________
14. Miles driven before failure: ___7800____________
User account number (aid): 34415
Posted by smcvt on 2002-10-31 18:38:54
In Reply to: Would you please fill out our ignition coil failure questionnaire if that's the problem (enclosed) posted by Placitas NM Audi on 2002-10-31 13:56:32
10
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__X__c. Rough idle
____d. Bad smell
__X__d. Drove it for a while until secondary symptoms made you park it and have it flatbedded to the dealer
____a. Yes
__X__b. No
____a. Mild
____c. Hot and dry
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? ___Colchester, VT_____
_Oct. 26 @ about 3:30 pm._________________
____a. Gentle
__X__b. Moderate
____c. Aggressive
__X__a. One
____b. Two
____c. Three
____a. Yes
__X__b. No
13. Production date of car (inside drivers side door pillar): ___could n't find it.___
14. Miles driven before failure: __7400 miles
User account number (aid): 27252
Posted by ralph m on 2002-10-28 13:41:50
In Reply to: Have you had a coil pack failure? If so, state specifics on this questionnaire (see examples). posted by Placitas NM Audi on 2002-10-22 14:28:37
11
1. Car?
x____a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
x____b. Just after starting your car
x____a. Shaking or excess vibration
x____b. Engine warning light
x____c. Rough idle
x____d. Bad smell
x____f. Loss of power
x____b. Drove the car home then had it flatbedded to the dealer
____a. Yes
x____b. No
____a. Mild
____c. Hot and dry
x____f. Cold but above freezing
Long Island, NY
10/27/2002 20:00
x___b. Replaced all of the ignition coils
____a. Gentle
x___b. Moderate
____c. Aggressive
x___a. One
____b. Two
____c. Three
____a. Yes
x___b. No
1-Sep
User account number (aid): 43847
Posted by Quattro Formaggio on 2002-10-22 14:37:14
12
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
__X__a. On the road
_X___b. Engine warning light
_X___c. Rough idle
____d. Bad smell
____a. Yes
__X__b. No
____a. Mild
____c. Hot and dry
_X___f. Cold but above freezing
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? ___mid-Michigan____________________
8. What was the approximate DATE and TIME of day or night that the failure occurred? _Oct 16, 2002 @ 4:45pm_
_#1__g. Coil that failed (#1, #5, etc)
____a. Gentle
_X___b. Moderate
____c. Aggressive
_X___a. One
____b. Two
____c. Three
____a. Yes
__X__b. No
13. Production date of car (inside drivers side door pillar): _____06/01_______________
14. Miles driven before failure: ___15,750_____
Re. If you're experiencing a coil pack failure, please tell us about it using this questionnaire:
User account number (aid): 35322
Posted by Flurry on 2002-10-21 21:41:29
In Reply to: If you're experiencing a coil pack failure, please tell us about it using this questionnaire: posted by Placitas NM Audi on 2002-10-21 13:29:29
13
1. Car?
__x_a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__x_b. Just after starting your car
__x_a. Shaking or excess vibration
__x_b. Engine warning light
__x_c. Rough idle
____d. Bad smell
__x_f. Loss of power
__x_a. Drove the car to the closest Audi dealer
____a. Yes
__x_b. No
____a. Mild
____c. Hot and dry
__x_f. Cold but above freezing
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? __Toronto, Ontario_____
8. What was the approximate DATE and TIME of day or night that the failure occurred? __8:30am______
__x_a. Replaced the failed ignition coil
____a. Gentle
__x_b. Moderate
____c. Aggressive
____a. One
__x_b. Two
____c. Three
__x_d. Information for all failures is imbedded in this one questionnaire.
____a. Yes
__x_b. No
13. Production date of car (inside drivers side door pillar): __car at dealer,sorry, will update.__
14. Miles driven before failure: 8,000 #1 12,000 #2
mine.....
User account number (aid): 29885
Posted by Aweyea (Ben) on 2002-10-21 16:28:38
14
1. Car?
_X__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
_X__a. On the road
__X_a. Shaking or excess vibration
__X_b. Engine warning light
__X_c. Rough idle
__X_d. Bad smell
__X_e. Excessively hot exhaust manifold
__X_f. Loss of power
__X_a. Yes
____b. No
I was in the left lane on a busy street and luckily there was a break in traffic to my right so I could safely pull over.
____a. Mild
__X_b. Hot and humid
____c. Hot and dry
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? ___Detroit Michigan______
8. What was the approximate DATE and TIME of day or night that the failure occurred? _____uhm around 4pm 6/26/02_____
__X_a. Replaced the failed ignition coil
__3_g. Coil that failed (#1, #5, etc)
____a. Gentle
_X__b. Moderate
____c. Aggressive
_X__a. One
____b. Two
____c. Three
_X__d. Information for all failures is imbedded in this one questionnaire.
____a. Yes
_X__b. No
13. Production date of car (inside drivers side door pillar): ______October 01_________
14. Miles driven before failure: ______10,552___
Another coil pack failure report
User account number (aid): 34833
Posted by ThosD on 2002-10-21 12:15:01
In Reply to: Coil Pack (Ignition Coil) Failures. If you've had coil packs fail, please open this posting. posted by Placitas NM Audi on 2002-10-20 22:23:16
15
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
_X___b. Just after starting your car
_X_c. Rough idle
____d. Bad smell
__X__e. Excessively hot exhaust manifold
____a. Yes
_X___b. No
_X___a. Mild
____c. Hot and dry
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? _San Jose, CA_______________
10/17/02_6:00 P.M.____
_#1_g. Coil that failed (#1, #5, etc)
____a. Gentle
____b. Moderate
_X__c. Aggressive
_X___a. One
____b. Two
____c. Three
____a. Yes
_X___b. No
13. Production date of car (inside drivers side door pillar): _01/02___________________
14. Miles driven before failure: ___6700____________
Reply for two coil failures
User account number (aid): 20982
Posted by AggregatVier on 2002-10-17 21:40:47
In Reply to: If you have suffered one or more coil pack failures please open this posting. posted by Placitas NM Audi on 2002-10-17 15:47:08
16
1. Car?
_x__a. 2002 A4 1.8T CVT
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
_1__a. On the road
_2__b. Just after starting your car
_x__c. Rough idle
____d. Bad smell
____f. Other (describe)
_1__a. Drove the car to the closest Audi dealer
_2__c. Parked it and had it flatbedded to the dealer from there
_1__a. Yes [almost rear ended on freeway]
_2__b. No [in parking lot]
____a. Mild
_x__c. Hot and dry
____d. Cold but above freezing
____e. Cold and below freezing
____f. precipitation (Raining, snowing, etc.)
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? __Los Angeles / SoCal_
8. What was the approximate date and time of day or night that the failure occurred? _1 Morning 7/19/02 ~8:00 AM, 2 Late Afternoon 7/25/02 ~6:00 PM
_x__d. Put in the same rev coil
_H__e. Rev of failed coil(s) if you know (H, J, B, D, etc)
_H__f. Rev of new coil(s) if you know (H, J, B, D, etc)
_??_g. Coil that failed (#1, #5, etc)
____a. Gentle
_x__b. Moderate
____c. Aggressive
____a. One
_x__b. Two
____c. Three
____e. I filled out a questionnaire for each failure. [Indicated by 1=First, 2=Second]
____a. Yes
_x__b. No
13. Production date of car (inside drivers side door pillar): __05/02_____________
14. Miles driven before failure: _1<200, 2<500__
First coil failed one week after picking up new car and second failed six days after that. No problem with any delays at dealer getting it fixed.
User account number (aid): 30924
Posted by snwguy on 2002-10-17 18:25:06
17
1. Car?
_x__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
__x_a. On the road
__x_c. Rough idle
____d. Bad smell
__x_c. Parked it and had it flatbedded to the dealer from there
____a. Yes
_x__b. No
____a. Mild
_x__c. Hot and dry
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? ____Ottawa,Westport___________________
8. What was the approximate date and time of day or night that the failure occurred? ___Afternoon____________
_x__b. Replaced all of the ignition coils
_x__c. Put in the latest rev coil(s)
__2__g. Coil that failed (#1, #5, etc)
____a. Gentle
____b. Moderate
__x_c. Aggressive
____a. One
_x__b. Two
____c. Three
____a. Yes
_x__b. No
13. Production date of car (inside drivers side door pillar): __02/02________________
14. Miles driven before failure: ___5000km________
Form Reply
User account number (aid): 43461
Posted by PhillyAudiA4 on 2002-10-17 16:58:58
18
1. Car?
_x__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
_x__a. On the road
_x__c. Rough idle
____d. Bad smell
_x__b. Drove the car home then had it flatbedded to the dealer
_x__a. Yes
____b. No
____a. Mild
____c. Hot and dry
_x__d. Cold but above freezing
_x__f. precipitation (Raining, snowing, etc.)
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? _Philadelphia______________
_Friday, October 11, 2002 8AM _____
_4__g. Coil that failed (#1, #5, etc)
____a. Gentle
_x__b. Moderate
____c. Aggressive
_x__a. One
____b. Two
____c. Three
_x__d. Information for all failures is imbedded in this one questionnaire.
____a. Yes
_x__b. No
13. Production date of car (inside drivers side door pillar): ____01/02____________
14. Miles driven before failure: ____8950_______
Form1
User account number (aid): 27909
Posted by Dustin A4 on 2002-10-17 16:37:43
19
1. Car?
X___a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
X___a. On the road
X___a. Shaking or excess vibration
X___c. Rough idle
X___d. Bad smell
X___d. Drove it for a while until secondary symptoms made you park it and have it flatbedded to the dealer (almost made it home)
____a. Yes
X___b. No (It was a Saturday with light traffic)
____a. Mild
X___c. Hot and dry
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? Midwest_______
8. What was the approximate date and time of day or night that the failure occurred? 8/17/02 1:00 PM_____
X___a. Gentle - Work/Home in traffic repeat
____b. Moderate
____c. Aggressive
X___a. One
____b. Two
____c. Three
X___d. Information for all (1) failure is imbedded in this one questionnaire.
X___a. Yes
____b. No
The car seems to idle rough. And I constantly worry when the next coil pack will blow. I know it's coming but I don't have a check engine light to prove it.
13. Production date of car (inside drivers side door pillar): Sept 2002___________
14. Miles driven before failure: 7500______
User account number (aid): 5167
Posted by MicaCreek on 2002-10-17 22:22:10
20
1. Car?
_X__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
_X__a. On the road
_X__c. Rough idle
_X__d. Bad smell
_X__f. Other - smell of buring electrical component(coil melted). This caused APC light and total engine failure.
____a. Yes
_X__b. No
_X__a. Mild
____c. Hot and dry
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? _outside of Longmont, Colorado___
8. What was the approximate DATE and TIME of day or night that the failure occurred? _9/15/02 10:30 am__
_1__g. Coil that failed (#1, #5, etc)
_X__a. Gentle
____b. Moderate
____c. Aggressive
_X__d. Other -car still being broken in
_X__a. One
____b. Two
____c. Three
____a. Yes
_X__b. No
13. Production date of car (inside drivers side door pillar): __06/02_____________
14. Miles driven before failure: __275__________
Re: If you have suffered one or more coil pack failures please open this posting.
User account number (aid): 29947
Posted by docjan_uk on 2002-10-18 01:39:20
In Reply to: If you have suffered one or more coil pack failures please open this posting. posted by Placitas NM Audi on 2002-10-17 23:55:36
21
1. Car?
____a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
2.0_e. Other (describe)
____a. On the road
____c. Rough idle
____d. Bad smell
_X__f. Other (describe) reduced power.
____a. Yes
_X__b. No
_X__a. Mild
____c. Hot and dry
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? ____LONDON______________
8. What was the approximate DATE and TIME of day or night that the failure occurred? ___Late morning...10:30?_______________
____a. Gentle
_X__b. Moderate
____c. Aggressive
_X__a. One
____b. Two
____c. Three
____a. Yes
_X__b. No
13. Production date of car (inside drivers side door pillar): ____8/01________________
14. Miles driven before failure: __~4500_____________
User account number (aid): 34717
Posted by DCS on 2002-10-18 07:07:26
22
1. Car?
_X__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
_X__c. Rough idle
_X__d. Bad smell
____a. Yes
_X__b. No
_1__a. Mild
____c. Hot and dry
_2__f. precipitation (Raining, snowing, etc.)
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? 1 - Central NJ, 2 - Upstate NY
1 - 7AM before work, 2 - 1PM weekend
____a. Gentle
____b. Moderate
____c. Aggressive
_X__d. Other (explain) {a mix of all 3)
____a. One
_X__b. Two
____c. Three
_X__a. Yes 1.8T sounds a little less refined than before, higher db in the cabin
____b. No
13. Production date of car (inside drivers side door pillar): I'll check later
14. Miles driven before failure: approx 4K before failure 1, approx 7K for failure 2 (I'll check to be sure)
User account number (aid): 21406
Posted by cjjk3 on 2002-10-18 07:23:24
23
1. Car?
__x__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
___x_a. On the road
___x_b. Engine warning light
__x__c. Rough idle
____d. Bad smell
_x___c. Parked it and had it flatbedded to the dealer from there
_x___a. Yes
____b. No
____a. Mild
__x__c. Hot and dry
7. What was your geographic location when the failure occurred (London, Phoenix, Taos Ski Basin, etc)? _____NJ__________________
8. What was the approximate DATE and TIME of day or night that the failure occurred? ___________9/2 and 9/20/02_______ early morning
x a. Replaced the failed ignition coil
__x__b. Replaced all of the ignition coils
__J__f. Rev of new coil(s) if you know (H, J, B, D, etc)
__2 and 4__g. Coil that failed (#1, #5, etc)
____a. Gentle
_x___b. Moderate
____c. Aggressive
____a. One
x___b. Two
____c. Three
____a. Yes
_x_b. No
13. Production date of car (inside drivers side door pillar): _____10/02_______________
14. Miles driven before failure: _______18000________
Add me!
User account number (aid): 31778
Posted by Ahorizon on 2002-10-18 08:31:50
24
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
1. Car?
_X__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
_X__a. On the road
_X__c. Rough idle
_X__d. Bad smell
____a. Yes
_X__b. No
____a. Mild
____c. Hot and dry
____a. Gentle
_X__b. Moderate
____c. Aggressive
_X__a. One
____b. Two
____c. Three
____a. Yes
_X__b. No
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__X__c. Rough idle
____d. Bad smell
____a. Yes
__X__b. No
____a. Mild
____c. Hot and dry
____a. Gentle
_X___b. Moderate
____c. Aggressive
__X__a. One
____b. Two
____c. Three
____a. Yes
_X___b. No
1. Car?
_____b. 2002 A4 3.0
_____d. 2003 A4 3.0
__X__a. On the road
__X__c. Rough idle
__X__d. Bad smell
__x___a. Yes
_____b. No
____a. Mild
____c. Hot and dry
____a. Gentle
__X__b. Moderate
____c. Aggressive
_X___a. One
____b. Two
____c. Three
____a. Yes
__X__b. No
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__X__c. Rough idle
__X__d. Bad smell
_X___a. Yes
____b. No
#NAME?
_x___a. Mild
____c. Hot and dry
____a. Gentle
__x__b. Moderate
____c. Aggressive
____a. One
____b. Two
_x___c. Three
____a. Yes
_x___b. No
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__X__c. Rough idle
____d. Bad smell
____a. Yes
_X___b. No
____a. Mild
____c. Hot and dry
____a. Gentle
__X__b. Moderate
__X__c. Aggressive
_X___a. One
____b. Two
____c. Three
____a. Yes
__X__b. No
1. Car?
_X__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
_X_a. On the road
__X__c. Rough idle
____d. Bad smell
____a. Yes
__X__b. No
____a. Mild
____c. Hot and dry
____a. Gentle
__X__b. Moderate
____c. Aggressive
____a. One
____b. Two
__X__c. Three
____a. Yes
_X__b. No
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
__x__a. On the road
__X__c. Rough idle
__X__d. Bad smell
____a. Yes
__X__b. No
____a. Mild
____c. Hot and dry
____a. Gentle
__X__b. Moderate
____c. Aggressive
____a. One
____b. Two
__X__c. Three
____a. Yes
____b. No
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__X__c. Rough idle
____d. Bad smell
____a. Yes
__X__b. No
____a. Mild
____c. Hot and dry
____a. Gentle
__X__b. Moderate
____c. Aggressive
____a. One
____b. Two
__X__c. Three
____a. Yes
__X__b. No
9
1. Car?
____a. 2002 A4 1.8T
__x__b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__x__c. Rough idle
____d. Bad smell
____a. Yes
__x__b. No
____a. Mild
____c. Hot and dry
____a. Gentle
___x_b. Moderate
____c. Aggressive
____a. One
__x__b. Two
____c. Three
____a. Yes
_x___b. No
10
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__X__c. Rough idle
____d. Bad smell
____a. Yes
__X__b. No
____a. Mild
____c. Hot and dry
____a. Gentle
__X__b. Moderate
____c. Aggressive
__X__a. One
____b. Two
____c. Three
____a. Yes
__X__b. No
11
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
x____c. Rough idle
x____d. Bad smell
____a. Yes
x____b. No
____a. Mild
____c. Hot and dry
Long Island, NY
10/27/2002 20:00
____a. Gentle
x___b. Moderate
____c. Aggressive
x___a. One
____b. Two
____c. Three
____a. Yes
x___b. No
1-Sep
12
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
__X__a. On the road
_X___c. Rough idle
____d. Bad smell
____a. Yes
__X__b. No
____a. Mild
____c. Hot and dry
____a. Gentle
_X___b. Moderate
____c. Aggressive
_X___a. One
____b. Two
____c. Three
____a. Yes
__X__b. No
13
1. Car?
__x_a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
__x_c. Rough idle
____d. Bad smell
____a. Yes
__x_b. No
____a. Mild
____c. Hot and dry
____a. Gentle
__x_b. Moderate
____c. Aggressive
____a. One
__x_b. Two
____c. Three
____a. Yes
__x_b. No
mine.....
14
1. Car?
_X__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
_X__a. On the road
__X_c. Rough idle
__X_d. Bad smell
__X_a. Yes
____b. No
____a. Mild
____c. Hot and dry
____a. Gentle
_X__b. Moderate
____c. Aggressive
_X__a. One
____b. Two
____c. Three
____a. Yes
_X__b. No
15
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
_X_c. Rough idle
____d. Bad smell
____a. Yes
_X___b. No
_X___a. Mild
____c. Hot and dry
____a. Gentle
____b. Moderate
_X__c. Aggressive
_X___a. One
____b. Two
____c. Three
____a. Yes
_X___b. No
16
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
_1__a. On the road
_x__c. Rough idle
____d. Bad smell
____a. Mild
_x__c. Hot and dry
____a. Gentle
_x__b. Moderate
____c. Aggressive
____a. One
_x__b. Two
____c. Three
____a. Yes
_x__b. No
17
1. Car?
_x__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
__x_a. On the road
__x_c. Rough idle
____d. Bad smell
____a. Yes
_x__b. No
____a. Mild
_x__c. Hot and dry
____a. Gentle
____b. Moderate
__x_c. Aggressive
____a. One
_x__b. Two
____c. Three
____a. Yes
_x__b. No
Form Reply
18
1. Car?
_x__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
_x__a. On the road
_x__c. Rough idle
____d. Bad smell
_x__a. Yes
____b. No
____a. Mild
____c. Hot and dry
____a. Gentle
_x__b. Moderate
____c. Aggressive
_x__a. One
____b. Two
____c. Three
____a. Yes
_x__b. No
Form1
19
1. Car?
X___a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
X___a. On the road
X___c. Rough idle
X___d. Bad smell
____a. Yes
____a. Mild
X___c. Hot and dry
____b. Moderate
____c. Aggressive
X___a. One
____b. Two
____c. Three
X___a. Yes
____b. No
20
1. Car?
_X__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
_X__a. On the road
_X__c. Rough idle
_X__d. Bad smell
____a. Yes
_X__b. No
_X__a. Mild
____c. Hot and dry
_X__a. Gentle
____b. Moderate
____c. Aggressive
_X__a. One
____b. Two
____c. Three
____a. Yes
_X__b. No
21
1. Car?
____a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
____c. Rough idle
____d. Bad smell
____a. Yes
_X__b. No
_X__a. Mild
____c. Hot and dry
____a. Gentle
_X__b. Moderate
____c. Aggressive
_X__a. One
____b. Two
____c. Three
____a. Yes
_X__b. No
22
1. Car?
_X__a. 2002 A4 1.8T
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
____a. On the road
_X__c. Rough idle
_X__d. Bad smell
____a. Yes
_X__b. No
_1__a. Mild
____c. Hot and dry
____a. Gentle
____b. Moderate
____c. Aggressive
____a. One
_X__b. Two
____c. Three
____b. No
23
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
___x_a. On the road
__x__c. Rough idle
____d. Bad smell
_x___a. Yes
____b. No
____a. Mild
__x__c. Hot and dry
____a. Gentle
_x___b. Moderate
____c. Aggressive
____a. One
x___b. Two
____c. Three
____a. Yes
_x_b. No
Add me!
24
1. Car?
____b. 2002 A4 3.0
____c. 2003 A4 1.8T
____d. 2003 A4 3.0
The following are inputs from those who have provided amplifying comments regarding their coil failure problems:
x 35517 (3) ... Lost #2, #3, and #4 all within 6 weeks of each other. Only have 6,000 miles on it.
x 37800 ... (posted 9/24) ... coil packs ... The coil pack for the #2 cylinder fried on the way home last night. Had the car towed to the dealer, and they replaced the coil pack today. When I picked up the car, I was told that the installed coil pack was an old series - part number 06B-905-115-H, and that they have ordered four new series coil packs - part number 06B-905-115-J, which will be in in about a week. (built 6/01)
x 12698 ... (posted 9/24/02) Had 1 replaced today. early build '02. also had the common fan controller failure and a catalytic converter - which I understand is unusual. Plus 2 window chips and a flat tire in 17k miles. otherwise very happy. they should throw us a bone though like $250 shopping spree in audi catalog. my 98.5 had a burnt out interior light bulb in 3.5 years and that was it. I guess this is the price we pay for when you buy the first year of a new model. ... 02 3.0 qms ming got in 10/01. 17000 miles. Read about problem here and knew right away when check engine light came on and was shakin all about.
x 21406 ... Well Folks another GD coil pack went this morning!!!!!! ... This is my second one in 3 weeks, I was the one who reported the labor day morning failure. ... This morning on the way to work another one failed as I was driving, I had to delicately pull off this major busy thoroughfare..!!!!!! ... Sat for an hour waiting for the tow truck, then a trip to the dealer and time to get the loaner, so now it is 11:20 and I finally am at work!!!!! ... This has got to stop!!!!!!!!!!! not only is it an inconvenience and now SAFETY issue, but I lose 1/2 day at work, will Audi re-embures me for that, I have to take a 1/2 day vacation,,,because Audi wont fix their KNOWN PROBLEM!!!!! ... As I reported before my build date is 10/01 and I have 18,827 miles. ... Coil pack failure update ... I convinced the Service Manager at Princeton Audi to replace all 4 coils packs today, my car is ready to pick up, but he stated that they are the exact same type of coil packs, and that there is no updated coil pack????? ... Moments ago I filed a complaint with NJ Consumer affairs, which everyone can do for their state. I also sent Audi 4 emails regarding this issue still with no response.
x 5167 ... (9/16/02) Just got it back - it was the #1 coil. (long) ... Here's the complete story: I was just out for a drive in my 4 day old 1.8TQMS Avant, cruising along with my dog in the back when the vibration started. Within a few seconds the check engine light started blinking and I pulled over. Shut it down and re-started to see if it would clear up, but no luck. The manual said to keep driving at reduced power, so I started towards home. Got about 7 miles down the road when I noticed a "hot" smell, so immediatly looked for a place to pull over. At that moment, the EPC light came on and the engine died. So, the dog and I waited an hour for the flatbed to arrive. By the time I spoke to the service manager this morning I had searched thru this forum and read about the coil issues, so I pressed him to replace all the coils if that was the problem. When I got it back, he had only replaced the one and said there was no point to replacing them all since the replacement was the same part as the original. But he did say that the current part is now the second revision, and they're working on a third. He didn't have an answer to the "hot" smell - I'm afraid I may have cooked the turbo and it's going to bite sometime down the road. Moral of the story: if it starts to vibrate, pull over asap and shut it down! Build Date: 6/02. ... (9/17) Update on my coil experience ... I talked to my Service Manager again today and told him of my concerns that I may have cooked something by continuing to drive (slowly) after the #1 coil failed, and that there was a "hot" smell seconds before the EPC light came on and the engine died. As it turns out, he told me that the bad coil they took out was melted - it literally came out in two pieces. The engine died because a fuse blew. I was afraid that the turbo overheated, just enough so it would fail in say, 49,750 miles just after the warranty expired.
But regardless, if you do experience the coil problem while on the road - you'll know it by moderate vibration under power, my advice is to get off the road as soon as safe and practical, shut down and call roadside assistence.
x 9160 (3) ... My Details ... Coil pack #4 blew first thing one morning at start-up in my garage. Car was towed in and dealer informed me that there were no coil packs in stock when they called later in the day. After a brief discussion it was decided to take a fresh coil pack off a car on their lot. ... 3 months later coil pack #2 and #4 die while in traffic. Same symptoms ... heavy shudder at idle and bucking under acceleration, awful smell and flashing check engine. Car was towed from roadside and dealer took coild packs from car on lot. I was also informed that it was not possible to change the remaining 2 coil packs under the warranty agreement.
x 36192 ... Coil horror story ... Last weekend, my wife and I drove to Santa Fe, NM from Boulder, CO. The 440 mile drive down was very nice. The next morning, I went to start my car and I was given a big surprise. My car started to vibrate violently at idle and maintained the vibration through some revving. My check engine light came on and I decided to use the Roadside Assitance so glamourously shown to me when I bought the car. I called Audi roadside assistance and they were not helpful at all. In fact, they were very rude. They wanted to tow my car to Albuquerque and fix it there. I asked "How do I get my car back to Denver?" She replied that that was not her problem. I basically had to bite the bullet and pay for the $1058 to tow to my dealer in Denver. How many miles does my car have? 5883. The guy who towed my car said that in August, he towed a BMW under warranty back to Colorado and BMW Roadside assistance covered it. Back to the story, my dealer looked at the car and immediately knew that it was the ignition coil. If Audi knows about this problem then why won't they pay for my towing? This was not my fault. Also, if my ignition coil breaks on another trip, do I have to pay another $1000 for the towing. This is my third Audi and I've always been happy. However, they are seriously getting me to look at BMW's.
x 26088 ... Haven't checked forums in a while, didn't know it was so common. ... I had a problem with my #4 coil too. Engine was hot, been driving for about 1/2 hour. Failed at
a light, thought my foot came off the clutch too quick
. Drove it back to the dealer, about 3 miles away, bad move? They said it wouldn't be a problem if I drove it. Can I expect more failures?
x 27909 ... Coil Pack #1 after 10 months & 7500 miles, Build 8/01, car was cold, drove about 5 miles from home and the light went off and the car lost all power, car was towed to the dealer (flatbed)........................................
x 36634 ... Build of 4/04, A4 3.0 Tip. #1 Coil pack failed at 375 miles. Same symptoms, started car in morning ran for 2 miles stopped and upon re-start car ran rough and CE Light was on. Drove 4 miles to dealer (luckily I was close to home) waited 1 day for part. All OK since I now have 4500 miles. Can't wait for the next one.
x 35322: After sitting over night went to start the car and was running rough. Brought it to the dealer with a flashing MIL light on. Dealership is only 2 mins. from my house. Had to leave the car the whole weekend. Coil number 3 went bad.
x 41619 ... Coil Failure - 3.0 2500 miles. Hot start coil #3 went after a mile. Build date 9/01. Thanks. ..................................
x 3591 ... I own a 3.0, and one morning after a cold start the car was idling a bit rough...then as I pulled out of the garage it went away. So I proceeded to the freeway, after about 3 miles the car started rattling and shaking like a Sherman tank with a bad idle...then the CE light starts flashing so I pull over and turn off the car and wait for a flatbed. As it turns out cylinder number 4's ignition coil was bad, what pisses me off the most is I was stranded on the side of a busy freeway (speed limit of 70MPH) with my infant baby girl (who comes to daycare at my work) for over an hour, actually about 1:45!! Not exactly a happy thing to have happen, especially during the morning commute when people are half asleep and try to do makeup or drink coffee at 70-85 MPH!!......................
x 20982 (2) ... Built 05/02, First coil died 7/19, first week. Second problem 7/25. Fine since @ 2K+ miles. Flatbed towed to dealer both times. Coils used to have brackets to hold them down. Brackets have now all been removed by dealer. Wife's car built 06/02 has had no problems in 2K+ miles ... Have to add my dealer, Keyes, got me in and out quickly and even did other checks and adjustments at no charge.
x 26140 (2) ... First one went around 7K miles. Dealer replaced it. The night I got the car back a second one failed. The dealer then replaced all four from a car on the lot. My build date is 7/01...........................................
x 22048 (3) ... I opened my hood and my exhaust comming off my turbo was glowing red ... So will the new coil they put on the car be fine? Addendum: As suspected the reason my CEL was blinking was due to a bad coil. And as it turns out this is the third time it has happend, (i bought the car with 13k) I just got off the phone with AOA and they said they could not replace the last coil till it fails. I said I would not accecpt that as a solution so they took my info and said they would get back to me. I am sure they will not replace it. If this last one fails while I am on a trip I will be really pissed. ........................................
x 29947 ... (build date is either 6/01 or 8/01, so lets say its 7/01 for averages sake.
Driving style is pretty much Cruising...
This happened after a series of long trips... after months in the city, we took it out to stretch its legs for the FIRST TIME, it pretty soon after a few long trips at 75-100 mph.
coils went early/mid August. Happened on a cold start... car became jerky... it wasnt a cold day but it had been off a while.) ... They replaced all 4. .........................................
x 32188 (2) ... Build Date : 07/01 ... Engine: 1.8tq tip ... Coil pack #3 went bad at 10,500 miles in June '02. ... MIL flashing, flatbedded to dealer. Coil pack #4 went when I was picking up my car the next day, MIL flashing again. Replaced 2 only, running without problem so far(15,000 miles).
x 34717 (2) ... 2 coil packs one at about 4k the other at about 7.5k I can't really give details about it until later though.
x 41380 ... Coil failure at 60 miles.
x 29762 ... Had ignition coil #1 replaced ... puffing, vibration, loss of power yesterday... Had the defective igition coil #1 replaced today
x 30278 ... 2002 A4 PROBLEMS!!!! ... OK, I visited this forum last year and posted my first problem which most of you took offense to. Most of you are Audi fanatics and don't want to hear anything negative in regards to them, but you need to OPEN your EYES!!! Few days after I brought my car home last October I noticed the first problem. Everytime I started the car it would cranck too many times before firing up. Took it in and first diagnoses indicted a faulty fuel pump. Got it replaced picked up my car and problem was still there. Took it in again, this time they said it was faulty injectors so they replace all my injector. Problem fixed. A couple of weeks later I go to start my car in my drive way and car's check engine light is flashing and car is shaking. I had to get it towed into my dealer. Diagnoses: ignition coil #1 went out, got it replaced, problem fixed. Today....driving on the freeway to go to work and all of a sudden car looses power and begins to shake and check engine light comes on. Diagnoses: ignition coil #1 went out again. All together, my car has been in for repairs about 6 times. I asked Audi to replace my car with a new one or give me my money back the last time this happened and they said no. Today, I contacted them again, filed a complaint with Consumer Affairs to invoke the Lemon Law. Oh, and get this, today while I was waiting for the tow truck at a Chevron station some A$$ hole reversed into my back bumper....luckily no damage to the car....let's just say I've had better days and better cars. So will I ever recommend Audi....HELL NO. I won't deny that when the car is problem free it is a dream to drive. But it's just not worth it. So I hate to burst anyones bubble, but Audi is not as reliable as you think. Just pray that these things don't happen to you!
x 26247 ... Same thing happened to me a couple of weeks ago. Bad #4 coil. dealer had it fixed in under 2 hr. ... DON'T drive it. Get it flat-bedded to your dealer. I think the blinking CEL means there's a problem w/ the catalytic converter, in this case, since one cylinder isn't firing, gobs of gas are going to it. Bad stuff.
x 30853 (2) ... In case someone's keeping score -- bad coil pack, #2 cylinder, @6000 miles ... I've seen others post the same thing -- are we approaching the kind of numbers needed to start thinking about a bad batch? My build week was in N0vember, '01.
x 32335 (2) ... #3 and ...#3 first time was a breeze, second time I had to wait in another city over the weekend ... In response to "A show of hands for 02 drivers who have had ignition coil problems please..."
x 34717 ... 3600 mi. evap emissions valve, ignition coil.
x 29762 (2) ... All 4 ignition coils replaced ... 2 ignition problems in a month. Last time only the defective one was replaced, but today they replaced all the other 3. Hopefully there will be no further problems on my A4.
x 6708 ... Had fan controller and coil #1 replaced ... Mine was built 8/01 ... replaced coil #1 (in response to "It seems to be mostly last year build dates that have the problem with coils.)
x 35622 ... Coil update, for those who care :0). It seems that #3 that was the culprit ...
x 24540 (2) ... Ignition coil failure again ... An ignition coil failed this morning, this has happened twice in the last 2 weeks. First it was #3 and now it's #1. I can't be the first one that has this at my dealer because they actually had the part in stock and I was in and out in 20 minutes. I barely had enough time to finish my coffee. Great service but hope #2 and #4 don't give in. I wonder if the replacement coils will have the same problem because I can't imagine this being an isolated incident. ... I see two alternatives: 1) a massive recall to replace the defective coils with bionic ones 2) a saturday morning egnition coil replacment workshop and free tool kits.
x 29885 ... #3 at 10552 miles (In response to "*drumroll* .... yup, bad ignition coil"). Build date: 10/01.
x 22662 ... Coil pack blown at 7000km, all 4 repleaced free at dealer.
x 15145 ... Had 1 of my coilpacks replaced too .. only 3400 miles on my car.
x 34429 ... Update: Coil pack problem ... Just thought I'd put in my 2 cents. Just had my car towed into the dealer 2 days before I was supposed to drop it off for my 10K service!...
x 21406 ... qty 1, product date 10/01
x 5511 ... Build date: 11/01. #5 went bad 8/15 and 5200 miles.
x 4559 (2) ... On my 2nd coil pack replacement in 2 weeks. What's going on here??? Recall planned? ... Thanks guys. My 2002 A4 1.8T has blown 2 coil packs now. Is there a recall planned?
x 36370 ... I was once nervous about the coil packs, then one went out at 4400 mi
... (in reply to "A4 Problems").
x 24224 ... build date: 9/01. Just went at 9800 miles.
x 35322 ... Mine has been in since Friday for them. Sux. (in response to "Anyone know if Audi fixed the coil pack problem in later builds of '02?).
x 30924 (3) ... Lost coilpack #3. Can't wait for the other ones to go - Woohoo. ... I have a March build date. x 30924 ... Flashing engine light - loss of power & shuddering = coil pack. I just had it happen to me last weekend. ... Build date: 02/02. Bad coil pack #2 after 5000 km. ... Hey NMAudi , Second Coil Pack failure #%$@! ...more ... Just had a second coil pack go Saturday afternon. Had it flat bedded to my local dealership . Fortunately one of the ownners and a porsche mechanic were still working when I arrived. They were extremely helpful and had me back on the road in about 1/2 hr. Im calling the dealership next week to try and get all the coil packs replaced. The mechanic noticed that the part number of the replacement coil pack was 1 letter different than my coil packs which he said 'might' indicate a change in the coil packs . I'll let you know what I find out.
x 31344 (2) ... Had 4 of mine replaced 2 weeks ago. Same symptoms as you had. First they replaced only one coil pack. I asked for them to replace them all, but they said they couldn't justify it, and they hadn't seen more than one go on a car. Sure enough, my second trip after the fix, another one goes. Luckily both acted up after starting the car at home, so I wasn't stranded. I firmly asked that the rest be replaced now. After a call to headquarters, they got it authorized and replaced all of them. (in response to "I think it's my turn! Check engine flash, rough running, and a flatbed tow to the dealer.
x 30198 (3) ... Lost 3 myself. (In response to "OK people, I'd like to do a poll here, could you post if you've lost a coil pack, then details.)
x 42324 (2) ... Had 1st coil pack go last saturday....got it fixed in 30 mins at the dealer the following Monday...today is sunday...2nd coil pack gone!! (2 in one week!) I will be demanding the dealer replace all of them and I will not leave the lot until they do!!! THis is BS! 8/31 posting - Rude awakening! ... Today is my Bday ... Get into my car to take it for a wash ... start the engine and Happy Birthday!! Engine just sputters, very rough idle, drove it around parking lot for a bit ... very rough. Exhaust smells like rotten eggs .. what the F*&#???? My first assumption is its running on 3 cylinders. Car was perfect up until I started it today ... any ideas on what it could be!! Thanks.
x 29160 ... Guess what?... Started car last friday for an afternoon drive and it began to idle like **** ... 2002-09-16 ... The long and short of it is that the car was flat bedded to the dealer where it sat all weekend! problem: Coil pack. Car fixed and I'm rocking. Pissed I missed an awesome early fall weekend driving in Wisconsin.
31778 ... Coil pack failure strikes again! #2 coil.. '02 Avant ... I have an early build '02 A4 1.8T Canadian Avant. It's the 3rd in BC - i ordered it 6 months before they were available. Today my coil pack went south. Noticed rough idle at startup this morning and restarted the engine to see if it would go away. Nope. Drove gently to work, but after about 2 miles decided to pull over - it felt like damage could occur if i kept it up. The dealership (Clarkedale vancouver BC) was pretty nice about it, but they only replaced the one ... Add me to the list of coil failures... booo.
x 38993 ... Add me (9/17/02) ... 2 coil pack failures (2nd occasion occurred after the first set had been replaced) ... In Reply to: Four more ignition coil (coil pack) failures today. Here's the log of coil failures with comments:
x 1366 ... Yes, it was a coil pack failure ... I had my car towed to Steve Taub in Santa Monica this morning. Of course they said we are not familiar with that issue on this car. After much insisting they aggreed to look at it right away while I waited and sure enough I was correct. #3 was the culprit. They would not change the other so I will call AOA today and complain. Service Manager said they are putting the same part on anyway. Car has 15,200 miles with a build date of 10/01. This is a bad situation because you could be along way from a dealer when these things go down. It make me think twice about driving my fine german motor car any distance. I thought that is why I have my old MG. Symptoms where rough idle, then MIL indicator on, then loss of power/very rough running and flashing MIL. We need to start a serious campaign with AOA. It may be time to consider legal advise, I hate to say it but they need a recall on this. This issue could be about personal safety, not just convienence. ... Earlier comments ... *%$@ I think I am in the coil pack club! ... I really never have liked any type of club. Started her up to drive home from work and seemed to be running a bit odd. After about one mile started running like ****. I did drive another two miles home and called for a tow in the morning. 15,000 miles 1.8t QMS build date 10/01. I am going to push real hard to have all four replaced. I will report in after I hear wht is up.
x BlackAvantA4Guy (1) ... Friend's '02 A4.
Other coil failure comments:
35362 ... Want an ignition coil recall? ... For what it's worth, I sent Audi a note about the coil packs asking about possible recalls using their Warranty, Service, and Parts feedback form on their web site. They responded with an e-mail saying that someone is available at 1-800-822-2834 (option 3) to discuss recall concerns Monday through Friday, 8AM to 10PM Eastern time.
x 27471 ... Re: Ignition coil (coil pack) failure update ... I have had 3 coil packs replaced in my A4 1.8T, its a 2001 but I figured its the same problem most likely. I was wondering what damage was done to my engine since I was told to drive it to the dealership all three times (about 15 miles each time). Please let me know ... Thanks!
x 31053 - After 8500 miles and 5 months of flawless performance I finally have a problem. This afternoon I went out to start my car and it was idling rough. As I started out of the driveway the engine light began flashing, the car was misfiring and had very little power. I returned immediately to the driveway and will call the dealer in the morning. Any Ideas? Did I just get some bad gas or could it be the coil pack problem that other people have had?
37728 ... I wonder how Audi will handle the engine damage ... bad coils cause detonation that gets past the factory knock sensor. Even with new coil packs, I have to believe that some engine damage has occurred.
39689 ... Planning to take a long trip to the south in a couple of weeks from Maryland and I'm a little nervous. Do to this unfortunate coil pack issue, I'm a little nervous to take the car on an adventure, only to be stuck in the middle of the woods, or an abandoned highway because my coil went POOF!! I have 4500K on the car and the buid date was 04/02. What would you do? Also considering I have a 1 year old and impatient wife with me? Leave it.....or.....Take it?
40723 ... Started car in the morning ... idled really rough, didn't seem to want to smooth out. Shut it down and then restarted, idled rough for a few seconds then smoothed out. No idiot lights came on. havn't had this happen again. Coming up on my 10K service I will bring it to their attention.
21336 ... Audi is replacing them before getting to the dealerships and switching vendors for the coils, or at least I read that they were (6/27/02).
27463 ... 2 weeks ago, started car, shook like crazy. check lite came on. turned off car, then on - OK since. Posted on 2002-09-16 10:41:41 In Reply to: 29160, I've included your posting in our coil pack history log. Anyone else not in the log?
25423 ... Cold start and car started to shake ... Brought it in this morning and dealer said sparks blew. Don't know much about cars...but the symptons sure sounds like the coil probelms some folks have had here. (Sparks? Coils? not same thing right?) I have yet to go pick up the car....will prob know more tomorrow. Any inputs?
43738 ... 2002-10-01 ... I have just had a coil pack failure. My car has done 16,500kms.
37209 ... 2002-09-30 16:01:00 ... Classic case as described elsewhere. They ( dealer) would not replace all the coils - said they did not know that 06B-905-115-J existed - I had to call Audi Canada if I want anything else ... I can no longer drive the car without worrying that it will fail - what the hell is the point of buying a new car. I am _furious_; if it happens again, I might jsut drive the frigan car INTO the dealership.
43787 ... 2002-09-30 ... I'll add us to the list. We have a 2002 A4 Avant (1.8T). Five times now in 4 months, our engine has run very rough, misfired, and the engine light comes on (yellow). Our dealership has no idea what to do about it. They say it is a "minor inconvenience". They have replaced the ignition coils twice now, but it just happened again each time (the last time, the new coils hadn't even been in for 24 hours). It has now been in the shop for several days, as they try to figure out what on earth to do about it. Right now, I think we are stuck with a car with a defective engine.
37209 ... 2002-09-30 06:13:06 ... I still can't believe it. I loved this car - until now. Reading these comments is somewhat scary. ... Story. Started car, car rumble, flashing light. Stop car. Swear, call dealer. Wait. Luckily, have internet access and familiar with forum. So, can't wait for them to phone and say this was first time they had seen this problem...BAM ... Any advise appreciated. Replace all coils seems the way to go, but what does that buy me - 3 months. Christ! Rained allot the day before problem. Anyone else notice that it happened after rainy day... thanks ...
x 5815 ... 2002-10-07 ... Update! Confirmed Coil Pack failure ... "Cylinder #1 ignition coil inoperative 5051 diagnosis of fault code #16685 misfire detected. Checked ignition circuit first. Ignition coil w/power output stage broken into pieces, not firing spark plug. Replaced cylinder #1 ignition coil." ... This is what Premiers Invoice says. Car works again. Only cost me a 3.5 hour tow truck ride, 4 hours waiting for car and 3.5 hours home. I would have rather worked. ... They replaced my "H" with an "H". I'm not sure why they don't have the J models. ... Oh well, another for our trusty log. ... (earlier) ... Yesterday my 1.8T started acting up. I promptly went on AW and saw that the symptoms that I was experiencing were the same as everyone else's coilpack issues. ... This morning I go out driving and the CE light finally shows it's ugly face for the first time. I was in my neighborhood and quickly went back to the garage. I checked the coils; they are the "H" models. My car has a build date of 11/01. Looks like I will be sitting in the tow truck for 200 miles to Albuquerque in the AM!! I hope that Premier has the parts or a loaner car! ... Special Thanks to "Placitas NM Audi" for compiling a list of all the coil failures. Made for interesting read! I will post the results tomorrow.
x 21696 ... 10/7/02 - Coil Pack??? I think mine went out today ... I was at the dealer today to drop of the cover that folds up on the back of my avant. I didn't want to leave the whole car so I just dropped of the cover. Well, as I am pulling out of the dealership my car looses power and the check engine light comes on. I pull over to the side of the road and the car is running very ruff. I turn around and go back to the dealership and say guess what you can have my car anyway because I think the coil pack just went out. Am I correct, does it sound like a coil pack failure?
x 34186 ... 10/5/02 - Coil Packs problem, I think. ... Just hit 8000 miles. Went for drive, and engine light came on. Noticed a drastic different in the engine sound and performance. The engine sounds like an old vw bug when it's rev'ng. Did a search and found some coil pack related posts which seem to support the conclusion. ... Has there been a recall of any type with the 2002 A4? I love my A4, but I didn't have anyt problems with my 120,000 miles Honda beater.
x 43461 ... 10/11/02 - Driving home from the train station today .. the MIL light came on and the car was idling really rough. I was able to run at reduced speed in 2nd gear, but that was about it. I was only about 2 miles from home so I decided to keep going (might not have been the smartest move). I live about 6 miles from my Audi dealer.. should I just drive it at reduced speed there tomorrow, or should I call a flat bed to come get it? Just for the records, my build date is 01/02 and I have about 9000 miles on it. ... Okay, my failure was on my #4 coil pack. They replaced it with a coil pack that the part number ended with an "H". My build date is 01/02. It took Audi RoadSide 4 hours to come get my car on Saturday which perturbed me a bit, but since I was just at home watching football, oh well. They gave me a 2001 A6 as a loaner .. not too shabby, but it's not my A4.
x 43847 ... 10/16/02 - Audi reliable? WTF? ... I've posted in the past about my stuck frong passenger seat and my "dead red" radio. These were minor annoyances, and both occurred in the last three weeks or month. Today the next little gremlin popped up, and I am pissed. Driving to class about 20 minutes ago, I kept getting a jerking sensation during acceleration, as if I was in 4th instead of second gear when coming out of a corner (I was actually in second gear). The "check engine" light also came on, and my chances of making it to lecture disappeared with that. I pulled a U and drove straight home, talking to Audi Roadside assistance the whole way back. WHAT IS WRONG WITH MY CAR? I will find out when the tow truck gets me to the dealership I guess. :-( ... Yes, sounds very much like those. Thank god for this forum! ... In Reply to: Do any of the coil failure experiences described in the attached link match with your experience? ... Now I have some knowledge and I'll perhaps have a little more leverage with the service people at my dealership, or at least with AOA. Audi Roadside told me they'll reimburse me up to $25 a day for car rental. Will that cover anything? I've never rented a car before.
Here are the account numbers of those who earlier reported ignition coil failures on this forum. Any additional comments from these A4 owners would help our cause (See below for comments already received).
39560
16140 (2)
41084
31788
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
39560
16140 (2)
41084
31788
change from mild to hot or mild to cold might be a factor (sort of a delta T thing).
that the weather at the time of failure is meaningful. Failure may be due to cumulative effects
of driving or engine heat. Do you have data that may show a correlation?
We have learned, for instance, that coils fail on any given cylinder randomly - No one cylinder is hit more than another (thus no need for a chart).
You have given me one idea ... I'm going to try to graph 'Temperature' against 'On starting car or on the road'. Intuitively, there seemed to be more 'on the road' failures when it was hot and more 'on starting car' failures now that it's cold. For what it's worth, the coil, now that it's cold, passes rapidly through a broader range of temperatures after starting the car than it did in warmer months.
As far as mileage before fail is concerned, here's the actual milage at time of failure numbers:
180
275
490
2200
3100
3100
3184
4000
4030
4400
4500
4500
4600
5200
5300
5401
5580
6700
6800
6800
7000
7400
7400
7500
7500
7500
7800
8000
8000
8500
8500
8600
8600
8950
9300
9300
9975
10000
10000
10275
10500
10552
11000
12000
12000
12400
12400
13640
14000
14900
15000
15000
15500
15500
15750
17000
17500
18000
19400
19400
22500
180
275
490
2200
3100
3100
3184
4000
4030
4400
4500
4500
4600
5200
5300
5401
5580
6700
6800
6800
7000
7400
7400
7500
7500
7500
7800
8000
8000
8500
8500
8600
8600
8950
9300
9300
9975
10000
10000
10275
10500
10552
11000
12000
12000
12400
12400
13640
14000
14900
15000
15000
15500
15500
15750
17000
17500
18000
19400
19400
22500
people that had failures relatively early say 6,000 miles or less; if they do a great deal of
sitting in traffic, or many short trips during the day? Does not matter what the ambient temps are (unless the car is in Alaska).
If a low proportion of these drivers fit the profile we can discard this theory (and I
can stop leaving my freakin hood open everywhere I go!). If it pans out, Audi will have an
added incentive to fix our problem... can you imagine parking lots of A4's, all with
thier lids in the air!
I had a COIL Pack failure on my A4 Avant 2001. It had about 21,000 miles on it. Started up my car one morning and it had a high idle and ran very rough. Called the Audi dealership and suggested having my car towed to the dealership. I am willing to fill out the questionnaire if you need me to.
beachcomber
14
07-26-2021 05:08 AM
uble1234
14
10-23-2020 08:07 PM
brandonb93
A4 (B7 Platform) Discussion
12
12-04-2018 01:16 PM
S4intheOC
09-08-2015 12:12 AM
