Looks like I need either both O2 sensors replaced or both Cats replaced.
Old 03-03-2009, 11:24 AM
  #11
AudiMick's Avatar
Default When the cats fall apart you will hear the death rattle.
Mine died on my B5 at 140Kmiles.
Old 03-04-2009, 08:35 AM
  #12
Joey T
Guest
Posts: n/a
Default Let it warm up for a minute after starting
Don't get on it until oil temp is up.
Old 03-05-2009, 09:36 PM
  #13
Jimax's Avatar
Default When all was said and done, just the passenger side cats + the 2 O2s cost me $1450
And I had those same codes when my car was VAGd.
Old 03-05-2009, 09:37 PM
  #14
Jimax's Avatar
Heh, mine were replaed at 96K miles.
Old 04-15-2009, 03:25 PM
  #15
SnowZach's Avatar
How did you determine that the cats were bad..
I ran the test but it didn't say the test failed, it just went from Test ON to Test OFF with no indication of pass or fail:
https://www.audiworld.com/forums/sho....php?t=2748273
Old 04-16-2009, 07:20 AM
  #16
pcasa's Avatar
Default me too...
replaced mine on my B5 at about 97K - rattled something awful - car in heaven now with its new cat
Old 04-21-2009, 12:45 AM
  #17
diagnosticator1's Avatar
"Cat efficiency below threshold", Upper limit exceeded, means the cats are not heating up as fast as they should, The VVT and the SAI are both involved with cold start up operation for quick cat light off, to allow closed loop fuel control asap. Therefore, check the SAI for leaks, etc, as that could effect the cat heat up time, as does several parameters for cold starts.
Mark VII
14
09-26-2023 10:11 AM
ilikeit
01-09-2016 09:24 AM
ilikeit
Pacific Northwest Discussion
11-20-2015 06:57 AM
ZPA117
A4 (B8 Platform) Discussion
09-08-2015 11:55 AM
raiderrider
12
09-08-2015 05:46 AM
Quick Reply: Looks like I need either both O2 sensors replaced or both Cats replaced.
