looks like Wayne's right-angle O2 sensor block took care of my O2-related codes...yay!
bad news: coolant is dripping down the front of my block, looks like the water pump is leaking - again. And to make matters worse, when the last one was installed, the head of one of the screws holding the water pump to the block snapped (possibly why it's leaking now, though that was over a year ago). Who wants to guess how much it will cost to have it drilled out/tapped?
edit: link to Wayne's block below, may help others running a HFC/TP that are getting O2-related codes<ul><li><a href="http://forums.vwvortex.com/zerothread?id=2942552">link</a></li></ul>
I used 2 spark plug arrestors, with one drilled out to fit the 02 sensor.
They have the same threads as the 02 sensor and cost like $2 at most autopart stores.
The only issue is the angle and whether there is room to mount them without hitting the body or sticking down too much.
x1rider
10
11-19-2008 01:04 PM
BSK
07-31-2008 08:31 PM
Pscheoverdrive
04-24-2008 08:17 AM
VorsprungTT
04-11-2007 04:21 AM
VorsprungTT
11-22-2006 01:57 PM
