Misfires galore
When the engine is cold my A4 misfires badly. If you leave it idling when cold, it will run fine for 5 or 10 seconds and then the rpm will suddenly drop down to 600 rpm, almost stalling. Keeps doing those rpm drops when cold. Once it warms up, everything is fine.
Here are the VCDS codes:
I think the first code is general misfire and the rest are misfires on cylinders 2, 3 & 4. Bad coil packs? They were changed under a recall ~60K (35K miles) ago. I changed the plugs not 6 months ago and they're gaped properly so it's probably not the plugs.
Any thoughts?
Code:
16684 - Random/Multiple Cylinder Misfire Detected P0300 - 008 - Implausible Signal - Intermittent 16687 - Shareware Version. To Decode all DTCs P0303 - 008 - Please Register/Activate - Intermittent 16688 - Shareware Version. To Decode all DTCs P0304 - 008 - Please Register/Activate - Intermittent 16686 - Cylinder 2: Misfire Detected P0302 - 008 - Implausible Signal - Intermittent
Any thoughts?
Fast Euro
07-19-2008 07:43 PM
redspook
07-25-2005 04:16 PM
