Mobil 1 15W-50?
Mobil 1 15W-50?
I'm about to do a 50K service on my car. So far I'm looking to do the following:
Fuel Filter
Spark Plugs
Engine Air Filter
Cabin Air Filter
Brake Bleeding
Oil Change
<b>Anything else?</b>
Also, I track my other highly modified, air-cooled car a lot so I have a huge amount of Mobil 1 15W-50 full synthetic oil in my garage. Being that the Audi will be driven in hot conditions this summer, I'm thinking of using the Mobil 1 !15W-50 higher viscosity oil (I use 5W-40 synthetic in the winter). <B>My question is, has anybody used this higher viscosity oil and is it VW approved for the 1.8T engine?</B>
Thanks!
Fuel Filter
Spark Plugs
Engine Air Filter
Cabin Air Filter
Brake Bleeding
Oil Change
Thanks!
VW502 Approval's based on generic ACEA A3 spec, which 15w-50 meets except mpg & cold stipulation
So, don't use it in the cold nor expect top mpg. (1.8t NEEDS good cold flow, not really an issue in summer, but you want to warm-up slowly)
Frankly, as an owner of a substantial stash of motor oil, even if I already had it, I would NOT use it in my 1.8t because there are much better options out there. Look at the Mobil 1 HM line, built like a race oil, if that's the target. Other oils offer max mpg/hp/service duty, like German Syntec or M1 0w-40 SS / 5w-40 TDT.
I'd actually mix it down with some M1 5w/10w-30 about 50/50% to get a decent visc.
As far as M1 15w-50, great in appropriate specs, but not when oil temps are low or in an engine with low-tension rings. Older SL version are MUCH better then newer SM and (ugh) Extended Performance 15w-50 (non) Red Cap.
So, mix it or use something else. Mobil ok's mixing grades of Super-Syn.
snagitseven
A6 (C7 Platform) Discussion
212
07-01-2020 04:28 PM
