My H&R 15mm track spacers
Old 05-26-2003, 09:59 PM
  #31
SilverTQ's Avatar
8mm or 15mm all round would look good, its just a little difference barely noticeable
Old 05-26-2003, 10:00 PM
  #32
SilverTQ's Avatar
Re: 8mm or 15mm all round would look good, its just a little difference barely noticeable
  #33
Member
Mike@Ikon Motorsport's Avatar
Yes, but generally am wheels will not make as signifigant a change as spacers.
Old 05-26-2003, 10:05 PM
  #34
SilverTQ's Avatar
Default Yeah, no doubt...everyone should be aware of the pro's and con's before making a mod
Same with chips (can hurt you car), to low springs..etc..
Old 05-26-2003, 10:06 PM
  #35
Member
Yep, hope it works out for you.
Old 05-26-2003, 10:09 PM
  #36
SilverTQ's Avatar
Default I ran rims on my B5 A4 that had an offset for an A6...
The rims were running out a little past the wheel hubs. Couldnt fit more than 225 or they would rub. That offset could have hurt my car, and I knew it, but never had any problems related to that.
Old 05-26-2003, 10:26 PM
  #37
Member
Default Great quote...
"..The hardcore racers don't like them. And rightly so since a tracked car is already stressed far further then any street driven car. I can see premature failure of wheel bearings."
A lot of it depends on how the car is treated. For day to day driving, I don't see it as being much of an issue. But that's not us, now is it
Mike
Old 05-27-2003, 06:46 AM
  #38
New Member
mark955i's Avatar
...poseur size.
Old 05-27-2003, 09:01 AM
  #39
New Member
IndyAvant's Avatar
Default Wheel offset and/or spacers won't affect kingpin inclination...
Refer to your diagram, the kingpin inclination angle is defined by the suspension, specifically, the relationship between the lower an upper ball joints. You could move the wheel out 10 feet and not change that relationship.
You will, however, increase the contact patch offset (D in diagram), which will increase the moment about the vertical axis of the tire. This will increase the loads on the suspension (tie rods, steering links, etc.) as well as increase the caster forces (the force that returns the steering wheel to center after a turn). Most normal spacers won't cause a suspension failure, but it will increase loads. Spacers are really to be used with increased offset wheels in order to keep the tire in the same relationship to the vehicle.
Old 05-27-2003, 11:22 AM
  #40
Member
Default "The pivot point should project through the center of the tire"
I didn't say that it would affect the kingpin inc. itself, but that it would change the contact patch, which is directly related.
Mike
Quick Reply: My H&R 15mm track spacers
