need help with this!!!!!!!
Old 04-07-2006, 06:19 PM
New Member
drageron's Avatar
Default need help with this!!!!!!!
<center><img src="http://pictureposter.audiworld.com/106255/subframe_a4_009.jpg"></center><p>2 questions!!
1. What is the piece called in the picture? it goes under the transmission and holds it up and the tranny mount connects to it. Its white metal and connects to the frame on both sides.
2. how do i find out what engine code i have, ex. AMW, ATW etc?
thanks
Old 04-07-2006, 06:41 PM
heateris's Avatar
Default looks like you broke your crossmember. how did you do that? your engine code in on a little tab (m)
Engine number
The engine number (" Engine code " and "Serial number") can be found on the rear left of the cylinder block.
Additionally there is a sticker on the toothed belt guard giving the " Engine code " and "Serial number".
The engine code is also given on the vehicle data sticker.
Note:
The engine code is also stamped on the front lifting eye (visible when engine cover panel is removed).
Old 04-07-2006, 06:43 PM
New Member
drageron's Avatar
Default Re: looks like you broke your crossmember. how did you do that? your engine code in on a little tab
some *** hole in storage was movin cars with a forklift and must have ****ed it up real good
Old 04-07-2006, 07:03 PM
New Member
drageron's Avatar
yea it might be where the ??## do i get one?????
Old 04-07-2006, 07:15 PM
ben gt/cs's Avatar
jesus
Old 04-07-2006, 07:40 PM
AudiWorld Expert
Projekt 8E's Avatar
I would just go buy a bottle of jack and drink til you pass out
Old 04-07-2006, 07:48 PM
Junior Member
Mateoloco's Avatar
big second, i'm 90% there
Old 04-07-2006, 07:55 PM
Senior Member
a4tis™[Bye Turbo]'s Avatar
a forklift?!?!?!?!?!?!?!?!?!?!
Old 04-07-2006, 08:06 PM
mcpath's Avatar
holy crap. I hope they cover the repair.
Old 04-08-2006, 12:11 AM
MRSK's Avatar
Default Ouch!!! If you are referring to the engine number, it is located...
on the side of the block below the intake manifold, close to the gearbox (1.8T). The spot is very hard to get to and you will need a torch with a flexible extention. Furthermore, the number is painted over at the factory, so you will need to remove the paint first.
Hope this help.
