Need help interpreting a noise I'm hearing........
Old 06-05-2008, 04:58 PM
Member
QuattroFan02's Avatar
Default Need help interpreting a noise I'm hearing........
lately I'm hearing a screeching sound. It only happens under hard acceleration for a brief second, usually from a dead stop. It appears to sound like a belt, I'm thinking that it could be my accessory belt. Is this a possibility? Is it possible that when I did my TB back in February they sent me the wrong (longer) belt and it's slipping under hard acceleration? Any ideas, what else could screech under hard acceleration? And it's definitely not the tires. TIA
Old 06-05-2008, 05:02 PM
Keeper of the Cash
Nate (ETKA+Scumbag)'s Avatar
Have you tugged on the belt? Does it feel lose? How old is your tensioner?
Old 06-05-2008, 05:04 PM
Member
Belt def. doesn't feel lose, the tensioner is new, replaced at the same time as TB.
Old 06-05-2008, 05:15 PM
Keeper of the Cash
What about the A/C tensioner? Was that replaced too?
Old 06-05-2008, 05:34 PM
Member
No, I wasn't aware of an AC tensioner. I did not replace that.
Old 06-05-2008, 05:42 PM
Keeper of the Cash
Default So you didn't do all your belts then. Replace the belts you didn't and the A/C tensioner
See if that fixes the noise issue(s).
Old 06-05-2008, 05:54 PM
Member
Default The B6 1.8t only has two belts, Timing Belt (toothed belt) and Accessory Belt (ribbed belt)
Those parts look like B5 parts. The accessory belt also runs the AC compressor and I don't think there is another tensioner.
Old 06-06-2008, 06:38 AM
CO AVANT's Avatar
Default A/C tensioner? Not sure what part you are meaning by that Nate...
there is no a/c tensioner on the AMB B6. There are rollers and the accessories belt tensioner...
Old 06-06-2008, 06:43 AM
Keeper of the Cash
Default Yes, those are my B5 parts. Ah, yer right on that. I was tired and shouldn't help when I am
However, now that I see the right diagram and that you do in fact have only one tensioning dampener.
I'd really go over everything with a fine tooth comb and make sure everything is running smoothly.
When I did my TB, I had a clicking noise from the new TB tensioner on cold starts for a few days, then it went away on it own. Since yours has been on since February, it could be a shoddy belt or bad tensioner that can't hold under acceleration.
Keeper of the Cash
Right, I see that (now).
Quick Reply: Need help interpreting a noise I'm hearing........
