NEW PROBLEM! The "Triangle with Exclamation symbol in it" came on while driving back from...
#11
well. I wish I could tell you more than the ECU and ESP sytem takes into account a myriad of systoms on the car to work properly.
Interestingly, you will also see an ABS malfuntion with a bad MAF at times. Easy to see. Just run out side and disconnect the sensor plug to your MAF (takes 5 seconds). You now have the ESP light and the CEL light stuck on.
cheers! Mike
cheers! Mike
#12
Although I'm not sure I want to deal with the CEL on for however many on-off cycles it needs before it resets itself after I reconnect the MAF.
d0nut s4
02-11-2016 04:48 AM
2002, 2003, a4, audi, exclaimation, exclaimtion, exclamation, explanation, inside, light, point, s4, symbol, triangle, troubleshooting
