Next MOD...Guess what Mr.Brown did NOT deliver...Pick'd up @ Stealership.
#35
This has been on the mod list for awhile but was dreading the fact that on my 2003 B6, the cigarette lighter socket flips open for use. Don't get me wrong, this is a good `cause the cigarette lighter is hidden, outta sight w/a clean finish look feature (I believe was lost on latter B6 models). Problem is that when using the Touareg Torch (LED Flash Light), the flip-feature will NOT work... Torch too long
Well Finally, pulled the trigger on the Touareg Torch and thought up a solution for my problem.
<center><b><u>Touareg Torch
<img src="http://images.snapfish.com/34243%3A7523232%7Ffp3%3B%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E2323696355665ot1lsi"></u></b></center>
Picked it up at the dealer...Dealer price was pretty reasonable while if ordered on-line, you may save a few bucks but pay it back in shipping...Not only that, but this way I get right away...
Well anyways, here is my solution; Check it out...
<center><b><u>Cigarette Lighter w/ Flip Feature</u></b>
<b>(note: adjacent storage bin)
<img src="http://images.snapfish.com/34243%3A7523232%7Ffp3%3B%3Dot%3E232%3C%3D649%3D54% 3A%3DXROQDF%3E232369656%3B272ot1lsi"></b></center>
When I was the dealer, I also pick up a cigarette lighter socket to retrofit into the adjacent storage bin. I drilled a ¾" hole into the velvet top plate & the underside w/a wood spade bit (cleaner hole) and inserted the cig/light socket. Pre-Wired all the goodies w/spade connectors "easy-crimp" wire taps.
<center><b><u>Set-Up before Installation
<img src="http://images.snapfish.com/34243%3A7523232%7Ffp4%3Enu%3D323%3B%3E558%3E459%3E WSNRCG%3D323278747%3A36%3Cnu0mrj">
Cig/Light Socket Assembly Inserted w/Wires Tapped to Existing OEM Cig/Light Power</u></b>
<b>(Correct Polarity tapped)</b>
<img src="http://images.snapfish.com/34243%3A7523232%7Ffp45%3Dot%3E232%3C%3D649%3D54%3A %3DXROQDF%3E232369656%3B289ot1lsi">
<b><u>Final Result
<img src="http://images.snapfish.com/34243%3A7523232%7Ffp47%3Dot%3E232%3C%3D649%3D54%3A %3DXROQDF%3E232369656%3B296ot1lsi">
<img src="http://images.snapfish.com/34243%3A7523232%7Ffp4%3Enu%3D323%3B%3E558%3E459%3E WSNRCG%3D323278747%3A38%3Cnu0mrj">
Final Result (light on / bad pic)
<img src="http://images.snapfish.com/34243%3A7523232%7Ffp47%3Dot%3E232%3C%3D649%3D54%3A %3DXROQDF%3E232369656%3B2%3B3ot1lsi"></u></b></center>
Whatcha guys think ???
Now I can have my cake (Cigarette Lighter w/Flip Feature) and Eat (Touareg Torch) it too !!!
And also an extra socket for other things that may come by ! 8^)
<b><u>Final Result
Awesome write up! Can you tell me/us how to remove the half moon shaped trim piece under the hand brake handle?? Im looking to replace this piece because mine is peeling. Also how did you remove the tray plate next to the cigarette lighter to put in the new one you made for the torch?
#36
<b><u>Final Result
<b><u>Final Result
...Can you tell me/us how you remove the trim piece under the handbrake handle. I want to replace this piece with a new piece - mine is peeling. Also how did you remove the tray plate next to the cig lighter?
Gzila850
09-29-2015 01:32 PM
Fah Q M3
02-16-2006 05:28 PM
