No hot air blowing in my 2003 Audi A4
I have a 2003 Audi A4 and my heater is not blowing hot air. It only blows cold air; even though, the heat gauge is normal (1/2).
Does any body have any suggestions as to what this might be? Thank.
No, it is not overheating. It works and blows fine as if it was working normal, but it just doesn't blow any hot air. I almost seem like it is something with the coil switch not working, but how would I go about fixing that.
the internal flaps which direct airflow over and or around the heater core, may have one of their electric motors gone bad...
One of my previous posts-<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/1085220.phtml">https://forums.audiworld.com/a4gen2/msgs/1085220.phtml</a</li></ul>
the water pump impeller from the factory is plastic, which is mounted on a metal shaft and can separate from the shaft. Keep us posted on what you find out.
