Normal sound with a FMIC?
Just went out to the bank and the first thing I noticed (since I had all windows down) was the pronounced boost sound. It's not as sharp as a whistle noise once I hit boost but almost like air sucking in noise.
No power loss, all of it is there...so thinking not a boost leak? Just wondering if it's normal to hear the boost sound more pronounced with a FMIC...
It's the first time I've heard it since installing it on Friday but this is the first time I've driven with all windows down.
do you have a boost gauge?
I had a slipped silicone coupler once and at exactly 10psi, I could hear air rushing under the hood. I did a boost leak test and found exactly where the coupler was slipping off the hose in 5 minutes.
Perhaps you can figure out a what psi you hear the sound and go from there.
No boost gauge :(
It's when boost hits the hardest, after 3,000 RPMs. As boost is building (mid to high 2000 rpms), slight sound as before I put on the FMIC.
do you have VAG Com?
you could log requested and actual boost and plot a graph so you could see if your actual boost falls way below requested, which could mean a boost leak.
