OH MY GOSH...HELP.....i think i did something pretty bad with the turbo timer...please helpe...
Old 01-10-2003, 03:16 PM
Junior Member
kontakterr61's Avatar
Default OH MY GOSH...HELP.....i think i did something pretty bad with the turbo timer...please helpe...
i turned off my car and my car was shutting down the seconds. right after i shut it down, i my frined came back so i had to turn the car on again, so i decided to turn the ignition coil back on while the car engine was still running, and when i turned the key, it made this weird loud noise from engine...do you guys think this damaged anything?
Old 01-10-2003, 03:19 PM
Junior Member
IBD SV's Avatar
Default To the best of my knowledge all you did was try and use the starter (m)
since the car was already running is should have made a loud noise and as soon as you let go it should have stopped. As long as you don't do this frequently it is fine, people can slip up and do it a lot and automakers build parts to with stand that stuff b/c they expect that people do it.
Old 01-10-2003, 03:22 PM
€uroDan's Avatar
Sounds like you used the start motor with the engine running. No big deal if only done very shortly.
Old 01-10-2003, 03:42 PM
Junior Member
yea, thats exactly what i did...do you think it would have done something bad when i did it?
Old 01-10-2003, 04:06 PM
Senior Member
shadyraven's Avatar
Default No worries. You engaged the cog on the starter against the fly wheel while the engine was running..
... hence the loud noise. As the others have said, as long as you don't this frequently, there won't be any problems.
Old 01-10-2003, 04:38 PM
Junior Member
KobeCow's Avatar
Default what turbo timer do you have and where did you get it installed?
i've heard that it's tough to get it installed on a B6 A4 (alarm conflict)
and how much you paid for labor?
any problems?
thanks
Old 01-10-2003, 05:48 PM
Junior Member
Default why would automakers expect people to do this?
why would automakers expect people to do this? it is impossible to do it without a turbo timer, and they probably dont expect the mass to get turbo timers.
Old 01-10-2003, 08:40 PM
New Member
protonzel's Avatar
Default Correct me if I'm wrong, but isn't this hard/impossible to do?
At least on my ignition switch, there's an interlock that prevents me from moving the key to the "start" position if I have already engaged the starter once before. Hence, I have to turn the key to off, then to start again to disengage that interlock.
Old 01-10-2003, 09:04 PM
Member
[ej257]'s Avatar
Default say your car is running with the key in and you get out and leave it running
you get back in the car and forget that it's running so you instinctively try to start the car. I've seen it happen plenty.
Old 01-10-2003, 10:03 PM
AudiWorld Expert
Projekt 8E's Avatar
but he pulled the key out. therefore unlocking the ignition
Quick Reply: OH MY GOSH...HELP.....i think i did something pretty bad with the turbo timer...please helpe...
