oil question...
Old 10-15-2004, 09:05 PM
Junior Member
MikeS02A4's Avatar
Default oil question...
with much preference give to Mobil 1 5W-30 synthetic oil, I'm now finding out that it is not approved by Audi. According to the list included in their recent extended warranty coverage for certain "oil sludge" related repairs, Mobil ! 5W-30 is not on the list, but 0W-40 is. Does this now mean that I have to change the type of oil in order to be covered under warranty? Or, if I wish to continue to use 5W-30, I need to change brands?
Any help/info would be greatly appreciated from the experts. t i a
Old 10-15-2004, 09:16 PM
Former Vendor
A4 - oh snap's Avatar
Default Damn. I just bought some Mobil 1 5W-30 tonight too.
I read the manual before buying the motor oil. It said that the car came with 0W-40 all season motor oil but 5W-30 would be fine so I pulled the trigger. You would think synthetic oil would assist in preventing the oil sludge issue. I was told the dealers don't even use synthetic oil. *shrug*
I hope someone knows. My oil is getting changed in about 10 hours.
Old 10-15-2004, 09:23 PM
akula-ssh's Avatar
Default I'd return the 5W-30 and get the 0W-40 if you can find it, since it's only the 0W-40 that...
qualifies for VW 503.01, which is the extended drain specification. Some other oils that has this spec include GERMAN Castrol Syntec 0W-30, Motul E-tech 0W-40, etc.
If I understand it correctly, AOA has only specified VW 502.00 as required oil in the recent sludge-related notice, so check the bottle of your Mobil 1 5W-30 and see if it's there.
Old 10-15-2004, 10:20 PM
Junior Member
MikeS02A4's Avatar
Default they told you wrong. NOW dealers ARE using sythetic oil.
as for what brand, I don't know. I was ALWAYS told to use the same brand everytime you change your oil.
Because I believe oils differ dealer to dealer, that's why I bring my own oil, just to be safe.
Old 10-15-2004, 11:00 PM
palewhitemale's Avatar
Default damn, you guys are behind.....
this was all covered about a month ago...pay attention in class.
The 1.8t MUST recieve synthetic oil and the NEW, LARGER oil filter. There was an audi service bulletin at the beginning of the summer about this.
I have been using 0w-40 since day one, however, the oil that they use (castrol syntec, I'm not sure on the weight) is both free and approved by audi.
As long as you use an audi approved oil and have service done every 10k (as per the stated service interval) you have a good case against any oil sludge issue you might have down the road. However, I'd be very surprised to see a synth car have those problems, especially with the larger filter,
hope this helps, also, you can search for more info.
-bill
Old 10-16-2004, 06:17 AM
Audi Junkie's Avatar
Default I assume 1.8t because you are referencing VW 502. Mobil 1 5w-30 works fine at 5k. For 10k, 0w-40.
<center><img src="http://pictureposter.audiworld.com/27563/visc2.jpg"></center><p>
Unless you are heavily modded, 5w-30 is ok, I'd add a 1/2 quart of 15w-50 though. Anyway, Mobil 1 5w-30 and 10w-30 are thin for the 30 weight range. A heavy 30 like German Syntec or 40 weight is best and they have the long-life VW 503.01 spec. IN a 3.0 there is a wide range of products that'll work, but it NEEDS the heavier oil to combat the burn-off. 5w-30 in a V6 is a no-no. Mobil 1 5w-40 SUV might be the way to go. If M1 0w-40 or 5w-40 is not available, Syntec 5w-50 is pretty easy to find and works great.
Oh, yeah. You DON'T need to meet any oil specs other than API SJ/SL/SM. If synthetic (A3 or VW 502) is required the manufacturer MUST provide it for free during the warranty period. This is why new cars get synth changes free and after warranty it's recommended. I would still BYO oil.
Old 10-16-2004, 08:51 AM
qfrog Ti20's Avatar
Default or just ask for the dealer stocked Belgium brew Castrol 5w40
ZVW-352-540-S
For a $50 oil change special we charge the following for parts.
$4.50 for each qt of oil
$.25 for drain plug seal
$8.50 or so for the 068 filter
we actually charge less for a walk in customer than we do to audi... by about 10% on parts.
Old 10-16-2004, 08:53 AM
qfrog Ti20's Avatar
Default its castrol
we use castrol, made in belgium... I'm not sure where the local synthetic castrol is made it might be domesticated.
Old 10-16-2004, 11:26 AM
englsh's Avatar
Dealer told me yesterday to use either Mobil 1 0W-40 or Castrol Syntec 5W-30.
Old 10-16-2004, 01:06 PM
FoKai's Avatar
yup!
Quick Reply: oil question...
