ok so i am trying to put in my k&n...
and i realzed i have no idea what i am doing. first of all the stock filter in the box is thick as ****. the one i am going to put in is skinny. does that matter? do i have the right part? also i am having trouble accessing the box to have enough room to take out the old filter. help please
there are screws at each corner of the airbox that when all are removed will provide more room to work with. Disconnecting the hoses on the top of the box will help as well. It is possible to swap without removing everything, but it will be tight.
the lower screws are the ones that are connected to the heat sheild? thanks for the help. are u running one in ur car?
undo the screws at each corner, you should be set. As for the filter itself, I have tried the K&N but am not using it now.
awdinut
32
09-03-2016 04:38 PM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
stormchaser1967
09-02-2015 08:48 AM
