Paging any Auto-RX veterans.....
I picked up some Auto-RX to clean the engine in the upcoming month or so. Just wanted to ask any of you: what dino oil did you use for the rinse portion of the process that Auto-RX specifically recommends to use dino oil? Given that the oil is only in there for 1500-2000 miles, and I don't plan on any track days during that time, I'm sure I'm safe with just about any oil close to 0W-40. But, doesn't hurt to ask.
(For my regular oil, I'm using Motul 8100 Ester E-tech 0W-40).
30 weights are ok. I used Mobil Delvac 15w-40, Motorcraft 5w-30, and Havoline 5w-30 for non-syns.
It is supposedly better to use the thinnest possible oil and as you know, dino for the rinse phase. I could rattle off a few diesel 10w-30 oils, but you probally won't find them anyway. I'd hit the Motorcraft 5w-30 or if you want a 40wt, find a Wal-Mart that has auto service they usually stock the Shell Rotella T Synth 5w-40. That is a HC or "Hydrocrack" synth, perfectly ok for ARXing. As far as treatment goes, I suppose yopu got 1 bottle. You need 10z for the inital treatment. I'd use about 9 instead and save 3z for a maintenance dose after rinsing. That's basicly what I do instead of a 2nd full treatment...a few maintenance doses. PS ARX is awesome.
thanks for the suggestions. I have one bottle and figured I'd do it around the 40K mile point.
The maintenance doses you suggest sound good too, even if I didn't do the full process and just did the cleaning prior to the next regular scheduled change.
Given the sludge letter, I see this as a must, and a very easy way to maintain the life of the engine.
Hadn't come to that point yet, but again, your suggestions seems good.
ARX just seems to recommend a new filter being good enough. So with our smaller filters on there to start the process, then the bigger one to collect the junk at the rinse phase, I should be golden for another 40-50K miles.
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
Touge.ca
Canadian Discussion
09-22-2015 06:30 PM
