Paging any welders, X1rider? What is the proper way to remove a downpipe flange to change its angle?
I guess i really just need to know how the remove the weld around the flange? It seems that drilling it out would be the only way. Is this right?
an angle grinder or die grinder with either a grinder wheel or a thicker cut-off wheel. The only problem is if you warp the cut-off wheel too much due to the roundness of the part, it may shatter (use a face shield, gloves, long sleeved jacket just in case).
A die grinder with a carbide burr may do well too.
I'm not a professional welder or anything but this is what I'd do.
I'd mount the downpipe (cat in my case) on a chop saw and cut parallel to the flange.
<img src="http://i132.photobucket.com/albums/q33/x1rider/fl1.jpg">
<img src="http://i132.photobucket.com/albums/q33/x1rider/fl2.jpg">
<img src="http://i132.photobucket.com/albums/q33/x1rider/fl3.jpg">
<img src="http://i132.photobucket.com/albums/q33/x1rider/fl4.jpg">
or rewelded by a proper welder:
<img src="http://pictureposter.audiworld.com/71130/dcp_2140.jpg">
<img src="http://pictureposter.audiworld.com/71130/dcp_2144.jpg">
<img src="http://pictureposter.audiworld.com/71130/dcp_2145.jpg">
