Paging anyone with the new version of ETKA
and the part numbers were the same for the bushings and clamps. They were tight but they fit.
Bushing clips: 8A0 511 439
Rubber Bushings: 8E0 511 327 A
Bolts for clips (2x per clip): N 101 277 06
They are the same for the B6 A4, I just confirmed.
See below.
<b>RS 4 Rear Stabilizer
<img src="http://www.Audicrazy.com/B6A4/RS4_REAR_STABILZER.jpg">
B6 A4 Rear Stabilizer</b>
<img src="http://www.Audicrazy.com/B6A4/B6A4_REAR_STABILZER.jpg">
See below.
clips for the S4 bushings and while its not the same size as the RS4 bushings, it'll fit if you force it (which you'll need to do).
the bushing part number you probably used is different (incorrect)
Correct bushing part # 8E0 511 327 <b>D</b>
Incorrect bushing part # 8E0 511 327 <b>B</b>
it wasn't even close, there was NO WAY it would fit without trimming the bottom of the bushing and bending the brackets. I already have a new set of bushings on the way and I'm trying to find the correct part number for the bracket.
hand and then finish it. Trust me, I'm not the only one who has done this. It works you just have to attach it to the car in the right order.
